LarryFine
- Henrico County, VA
- Electrical Contractor
I also do the bend method to split the spiral, and usually bend and break the metal with my fingers. This leaves the broken edge rounded away from the conductors. Sometimes I also nip a point off.
I'm always meticulous about shaping the metal to protect the insulation. I usually use bushings, depending on how I feel about the need, and put them on before trimming the plastic wrap.
One more thing: when there's a difference between the two terminations, I make sure the end landing in the 'weaker' support is the end with the spiral on the outside, for better pull-out resistance.
