I can't even remember what I had for breakfast today. :grin:mdshunk said:Hmmm... remember who makes that? I know the roto-split people make an electric one that looks like a little Skil saw.
JohnJ0906 said:I only use a hacksaw on the large sizes, say 1/0-3, or something like that. Usually, I use Greenlee roto-splits, or BX cutters.
There probably are people who do, but that's just punishing. Lacking the Roto-Split, and good snap and a pair of dikes works good.Awg-Dawg said:I took it as some use a hacksaw on the small stuff.
Awg-Dawg said:For the life of me, I can't grasp on how to use a hacksaw on MC.
It seems too small to try and cut. Any enlightenment?
Are you sure? There are MC connectors that look nearly identical to a romex connector, but have a "bottom" in them.76nemo said:O.K., another subject/question. I have seen several electricians blow a fuse over using a 3/8th's NM connector in a bind on MC. If you know what the heck you are doing, do the rest of you see that as an issue in your eyes??? I don't mean an entire factory, but you get my point. I noticed ALL of our new office space has Romex connectors, I didn't say a thing.
iwire said:I do, and I can beat a rotosplit in most cases.
You cut across the armor at an angle, with aluminum jacket and a sharp blade one or two strokes will do it,.
Beware though, until your practiced at it you will run the saw over the back of your thumb. :grin:
only if the guy using the rotosplits is an idiot...iwire said:I do, and I can beat a rotosplit in most cases.
mdshunk said:Are you sure? There are MC connectors that look nearly identical to a romex connector, but have a "bottom" in them.
Try this one on for size:
Tell that engineer that a Roto Split didn't even exist until 1973, and guys were cutting AC with a hacksaw or snips for 20 years previous to that. Ideal made a special "nipper" tool for cutting AC and MC armor, that had a hawk bill that would nip a coil of armor. Apparently, they don't make it anymore, but I'm sure I have one around someplace I can take a picture of.76nemo said:I had an engineer give me a talking to because I use the unwind/snip clean/taped redhead method. He told me it was very unprofessional, any good electrician is to know that only a roto-split was to be used on MC
emahler said:only if the guy using the rotosplits is an idiot...
Sounds like a new event for the electrician X games.iwire said:I do, and I can beat a rotosplit in most cases.
mdshunk said:Sounds like a new event for the electrician X games.
Wow! That's unbelievable.iwire said:I have raced my buddy before when making a bunch of whips. :smile:
But it was hack saw vs hack saw and it was ended up about even.
mdshunk said:Tell that engineer that a Roto Split didn't even exist until 1973, and guys were cutting AC with a hacksaw or snips for 20 years previous to that. Ideal made a special "nipper" tool for cutting AC and MC armor, that had a hawk bill that would nip a coil of armor. Apparently, they don't make it anymore, but I'm sure I have one around someplace I can take a picture of.
http://www.seatekco.com/lcd.htm
Might have been a "spec inspector" rather than the actual electrical inspector, maybe?ishium 80439 said:Slight tangent, I had an inspector a few years ago pull out random MC termination to see if they were done w/ a splitter. They all were so I didn't have a problem but was real curious where he would have found that in the NEC
mdshunk said:Might have been a "spec inspector" rather than the actual electrical inspector, maybe?
