Need to install a sub panel next to an old 200 amp main panel with no main thats fed with an underground 3 wire system from a rural meter loop on pole.Where do you land the new subpanels neutral and ground on old panel?Do you have to separate old neutral and grounds on old panel?And should there be a main breaker installed in old panel?
