GG
- Ft.Worth, T.X.
Does a sump pump require a GFCI outlet or do most sump pumps already come with some type of GFCI protection built into them? Any NEC articles that could clear this up for me? TY
It's not legal but many do it that way.Oakey said:I put them on a single rec no Gfi.
I would say that a sump pump does meet the defintion of "Utilization equipment" which is what "Appliance" says. Or am I missing something?Dennis Alwon said:I disagree--- I don't think a sump pump is an appliance. Would you allow a single recep. in a crawl for a condensate pump. I would think not.
GG said:Does a sump pump require a GFCI outlet or do most sump pumps already come with some type of GFCI protection built into them? Any NEC articles that could clear this up for me? TY
Dennis Alwon said:again I think this is a loose interpretation of the rule. I do not think a sump pump meets the meaning of appliance but we could argue that forever.
I agree with what you're saying. Just another topic open for never ending opinions.wbalsam1 said:A sumppump is installed in a sump hole. It's a machine used to force a liquid through it by suction or pressure. It's a mechanical device that changes the application of energy. Appliance derives from the word application and how machines apply force. I think a sumppump is a "utilization equipment". The definition of equipment in the code even mentions appliance. I don't want to argue it forever, though.
stickboy1375 said:None the less, I believe the code lets you use a non gfi receptacle behind a fridge or freezer is because its not readily accessible... just like a ceiling mounted receptacle in a garage (non gfi protected...) I agree with Dennis...
Oakey said:Inspectors are always telling me that a single receptacle on a airhandler/furnace is acceptable for the condensate pump . Most of the time it is in the basement and readily accessible on ground level. It's the reason I use singles on sump pumps and the like. Is this wrong? I am here to learn not trying to be a pain.
