- Windsor, CO NEC: 2023
- Hospital Master Electrician
Re: Switched Din. Rm. Outlet?
If you look closely, you don't even need a light in stairs. If you supply a light, it needs to be switched at both ends. If you don't, you don't.
I think if this article were written in plain english, without circular references, it would be 1000 pages long. It sucks, but it's tricky to pick apart. I've been trying.
Either that, or it just comes down to the fact that the NEC consists of minimum requirements, or so we're told. In the end, the only required lighting outlets are in the bathroom, kitchen, and human-sized egress doors.Originally posted by physis:
Edit: I have no doubt that the intention is that the lighting outlet not be on the SA circuits. But appearantly CMP 2 can't figure out how to write that.
