goldstar
- New Jersey
- Electrical Contractor
I hear ya !!!. I have about the same time in as well
Clear wirenuts you install with a Phillips head screwdriver bit on a cordless drill:
http://www.scru-it.com/how_to.html
I've seen that with conventional wire nuts, the catch is that sometimes the wire snaps off where it was stripped. Over twisting is not kind to conductors either...
And another tourquing tool to carry.:roll:Shush, or UL will require torque specs for wirenuts.
I have never taped wirenuts, I don't see the point.
More importantly, why wouldn't you wear suspenders with your tool belt?
If the connector was going to fall off anyway - the connection likely isn't a very good one, tape won't change that.
You should pull on each conductor after making the connection to ensure it is secured in the joint whether you plan to tape or not.
I can't recall any wire nuts ever coming loose in motor boxes, though I probably have seen it a few times and just don't remember, but I also occasionally find one come loose (or more likely was never on right in the first place) in non vibrating locations. Installer error is probably the biggest problem here, I occasionally don't like the condition of a connector and throw it out, the guys that don't get paid as much don't care they just want to get the job done so they can do whatever it is they do when not working. I've had polaris type connectors fail - but the ones I recall failing were ones my help installed and I have no idea if they got them correctly installed in the first place. I seldom have a connection that I made fail without some unusual circumstance contributing to the failure, but being the owner of the business you learn those little things like that cost you down the road if you don't pay attention, your help gets paid by the hour whether it fails or not.To keep your tool belt from dragging your britches down!
And the point of taping wirenuts, in my industry anyway, is that wirenuts in peckerheads on motors can and WILL vibrate lose, and the tape is to hold the conductors together and stationary in respect to each other as much as to hold the wirenut on. Then there is no unequal tension an any one conductor to aid in the vibrations loosening efect.
Most modern connector makers don't require pre - twisting, but it is not prohibited either.i have seen many where the coil inside has pulled away from the plastic, but the tape was still holding the cap over the wire. likely due to cheap pos nuts, and you never know what shows up on a jobsite, and what does show up is what is to be used. the tape would provide a little safety if you were digging in the box and the wires were being moved around, etc. and most of the time i bend the wires up into the box to get the advantage of gravity.
as for twisting the wires together, isnt that dictated by the nut maker? many makers instructions do not say to twist wires together 1st.
and those scru-it nuts, doent look right to me, the torque being applied is twisting the wires together for ~4" possibly more. this might mean little force holding the bare ends inside the coil. if you held the wires flat just under the cap and then used a torque style cordless, that would be better.
the instructions i see dont say "prohibited" but do show just stripping wire to proper length and then holding them parallel/even while twisting nut on. under NEC code one must follow manufacturer's instructions. and for clarity, i left out stranded wire.Most modern connector makers don't require pre - twisting, but it is not prohibited either.
Which tells us what we already know: There is no one way to do just about anything that works in all circumstances.believe it or not , every box of wire nuts has instructions written on it.I've heard of elevator mechanics using tape on wire nuts because of vibration .
I know cable TV installers do not tape their connectors because of trapping moisture and degrading the connection properties
Basically the same reason you won't tape a wire nutCATV connections are highly water resistant with compression fittings installed correctly. I would never tape such a termination because it's unnecessary and a waste of time.
So reading through this I can say I've taped wire nuts as well just cause it was what I was taught. Now seems kinda stupid if they're put on right.
So another question... how do you guys feel about wago push on connectors?? We have them in stock but I've never used them before. They seem like a fast and easy way for multiple wire connections just wondering about reliability or any horror stories lurking about.
