mivey
poco charges you for kWh use, right. so how much do they charge me for my 1kW bulb ??
On a traditional residential rate, the bulb charges would vary with the energy. The rest is a monthly customer fee that won't vary with the bulb usage.
The POCO charges for many things and they are billed out depending on how they vary with measured data and by what other data is available.
At the fundamental level, costs are assigned to four categories (works this way for water, gas, etc. also):
1) Customer: Things that are based on just being a customer, even if nothing is used, like rendering a bill. The meter is read every month so we have basic meter reading costs, bills are generated every month so we have basic billing costs, a basic service is needed to be connected to the grid, etc.
2) Demand: Things that vary with how fast energy is exchanged with the system. This would included generator size, conductor size, transformer size, peak system management & control, etc.
3) Energy: Things that vary with how much energy is used. Includes many variable costs like fuel costs, wear maintenance, etc.
4) Direct: Things that can be directly attributed to the customer. Would include things like requested extra facilities, or specifically dedicated equipment, even charges for a water heater bought from the POCO.
Ideally, you would want to measure both energy and demand but due to historic meter costs, some customers like residential and small commercial have only energy meters. The traditional residential or small commercial rate then has to bill the costs from the four categories using only monthly charges and energy charges.
Often the best effort is made to estimate things like the demand/energy ratio based on load studies and figure out how to wrap demand costs into customer and energy charges. This is not an ideal situation but works sorta ok until you introduce things that mess up the traditional load shapes (like distributed generation) and you then would be better off to measure the demand directly rather than trying to estimate it based on traditional load shapes.
It is a rate. You may be speaking to the fact that power is a rate that is time dependent because we USUALLY measure it over some time interval and it is the average power over some time interval. You could measure instantaneous power but we USUALLY don't.the definition of POWER is energy "produced" or "consumed". and to do that you cannot have a # that is missing time variable.
But no mistake about it, power is a rate.
Would not change the fact that power is a rate of energy exchange/conversionwould be much easier if things were just kept in std SI units.
They use miles driven/gallons consumed, much like you would do by hand. The "instantaneous" mpg uses fuel flow or something similar and is not as accurate over the long haul.and those in-dash car MPG stats, are lying to you folks. better go look at how the car ECU calculates MPG's, because unless the car ECU monitors fuel flow rate with a high sampling rate (several ways to do this, no car i know of does), the MPG thingy in your dash is a feel good meter.
