changing R, not from mag field. interesting. how about this one.
i have a 0.1Hz AC voltage on small coil, it produces a mag field that follows current and separated from voltage by Φ. the coil is fixed on a horizonal table. just in front of the coil is a perm magnet which sits upon a frictionless oil surface. when the AC current is on the magnet moves back and forth and the 1way trip is 2.5cm. there's work being done, but from where? where is the energy coming from that creates the required force to move an object of mass? energy is being transformed from mag field into work. if i add a little mass to the magnet then what? well, the magnet still moves back and forth yet the distance has decreased slightly, hmmm, same amount of work though. the reactive energy within the inductor is in the mag field, some of that energy is coupled out to real work. but wait a sec, the input side of the coil has Z=R+jX, but the VAr (energy, or imaginary power) associated with jX is partially (or fully) transferred to the magnet movement.
