- Placerville, CA, USA
- Retired PV System Designer
There is only one paragraph! :?See the last paragraph of that post.
Cheers, Wayne
Cheers, Wayne
Sorry, I thought you were referring to post 754.so two different amps at the same time? how is this shown in post 753? the amps waveform is shown as V(t)/Z for amplitude shifted by phi.
Cheers, Wayne
Well, it appears that XL is greater than R, which means the phase shift should be greater than 45 degrees. So I'm not OK with that part. Also, if it is a real inductor, would R be that high?are you ok with this plot of a real inductor.
Since phase shift has to do with the relationship of how two different quantities vary in time, it doesn't make sense to say "at any given time t". At any given time t, you just have a voltage and a current, there's no notion of phase shift at a single point in time.at any given time t the voltage will have phase shift of 37.016
I don't follow the question.you are also ok with saying that for any time t that t can be any vertical line on this graph, yes?
Cheers, Wayne
That's a good point. In fact, if you had outside knowledge that I and V are sinewaves, then each one is determined by just three parameters. So most any three values, e.g. I(t), I'(t), and I''(t) at a particular time t, will determine the sinewave.At any time t there are values for dI/dt and dV/dt. If, at the time you pick, one is positive and the other is negative that is at least a notion of phase shift.
This one's close, but arctan(1.5/2) = 36.87 degrees, so for the given R and XL, the phase shift should be 36.87 degrees = pi/4.88 radians.blue voltage = 3sin(x)
red amps = 1.2sin(x-pi/4.65)
yellow XL = 1.5
green R = 2
lt blue Z = 2.5
phase angle = 38.69
Nope. As previously discussed, the power flow at time t across the inductor is not I(t)2XL. It is I(t) * I(t + 1/4 cycle) * XL. If you fix that, plus the phase angle issue, your calculations should agree.so the instantaneous power at any given time (radians) is
[(1.2sin(Θ - pi/4.65))2*R] + [(1.2sin(Θ - pi/4.65))2*XL]
Cheers, Wayne
Great, I agree with the above. Once you've done that, P(t) = I(t) * V(t).i not following, the graph already shows the phase diff, dropping in a vertical line to represent time "t" gives us V(t) and I(t), the phase shift is already accounted for.
But in your post, you wanted to calculate the power drop across the resistor and across the inductor separately, add them up, and check it matches the total power. To do that, you need to use the voltage drop across the inductor, Vinductor. Unlike a resistor, the voltage drop across the inductor is NOT IXL. So the formula for power flow across an inductor is NOT I2XL.
Cheers, Wayne
OK, my answers have been based on a circuit consisting of a pure resistance in series with a pure inductance.i have one discrete component, the R is built into the coils of the wire that make up the inductor.
For a single component, you measure the current through the component, I(t), and you measure the voltage across the component, V(t). Then P(t) = I(t) * V(t).
So, is there a further question?
Cheers, Wayne
but due to the phase shift, didnt i show that V(t)I(t) != I(t)2(R+XL)Then P(t) = I(t) * V(t)
And you can still treat your single component as such, so the answers are applicable.OK, my answers have been based on a circuit consisting of a pure resistance in series with a pure inductance.
That's right, we agree. The power across an inductance is NOT I2XL.but due to the phase shift, didnt i show that V(t)I(t) != I(t)2(R+XL)
Cheers, Wayne
