FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
what? it totally does. the definition of watt is not the same as "power dissipated" (aka "consumed"). if i take 10200eV and move it from inductor to cap via wire with zero R, i move it via watt units yet no power is consumed.Volt-Amperes does not directly equal Joules per second.
eV is a better unit to use when we get closer to what is really going on from the physics view.
This is an incandescent bulb filmed in slow motion, with a 50 Hz AC power source. You can see that the power is not steady, but instead comes in cycles. So the Wattage rating on the bulb, is really the average Watts over a cycle.
https://www.youtube.com/watch?v=eUprJS9sXYU
what you see is not what you get? if you place a sensor on generator shaft to monitor magnetic impulse jitter, does it match the frequency of the bulb filament as seen in that video? you tell me.
