Let me ask you gentleman , can you wire a three way so that when the light is on ,:? both switches are up and when there off both switches are down.
with the 4 way in there, or with just one wire between, but landed on opposite traveler terminals of the three ways. You can do the same thing with two single pole switches in series with one another.Let me ask you gentleman , can you wire a three way so that when the light is on ,:? both switches are up and when there off both switches are down.
Tell me about it!! Real professionals know to use touch-up paint on the slots so they don't showA debate over plate screw orientation. :slaphead:
Merry Christmas everyone.![]()
Who installs one right-side up and one up-side down so that both switches can be in the off position when they are both in the "off" position?
You do not need to think at all about how you might wire the circuit, the requirement is logically inconsistent:
1. You must be able to turn the light on or off from either switch, regardless of the state of the other.
2. With both switches down the lights must be off.
Combine those two and it is logically required that putting either switch in the up position turns on the light.
From that state, go to the switch that is down. To change the light to off from there the only option is to move that switch to the up position.
Which contradicts our requirement that both up must be on.
If you allow momentary contact with latching or toggling relay(s) or multiple throw switches you do not have this limitation.
you guys crack me up... 11 pages! and not one mention of what we call a three-way grenade, the funnest part of hot checking other peoples crap!
Please elaborate.
White Out for ceiling tiles? must have been a pretty good roof.
If you damage the finish on white suspended ceiling tiles typical office 'white out' will work as touch up paint.
But boundary conditions are important. If, for example, you walked so slowly that it took you an hour to walk that block vs. ran it in 20 seconds, I guarantee that you'd get wetter walking if the rate of rainfall were constant.When I was in High School we did an experiment in physics class on this. Our instructor lived about a block away from the school and wanted us to find out if he would be drier walking or running to work/home when it is raining. We took some big sheets of paper out in the rain and walked with some, ran with others. Our test results were that it didn't seem to matter very much - so he could walk or run, depending on his mood at the time and would likely be about the same wetness level.
Well there is all kind of things that can change the outcome, rain rate, droplet size, wind speed, wind direction, stepping in a puddle along the way....But boundary conditions are important. If, for example, you walked so slowly that it took you an hour to walk that block vs. ran it in 20 seconds, I guarantee that you'd get wetter walking if the rate of rainfall were constant.
In US usage the third or additional switches added after you have the required two "three way" switches to start with for two control points are four way switches, and that is why it is hard to understand exactly why.I didn't read the whole replies but what I remember the three way switch the one to be inserted in the circuit when you want to have a three or more locations for control
3 point, 4 point........no two point need apply......
Now way back in my past, i posed the same Q as the OP.
The old timer (K&T tenure) pivoted his foot on his heel
He said the 'heel' is the common, and it's either ON-OFF-ON or it's OFF-On-OFF , depending on orientation
Ergo '3 way' literally meaning 3 functions to get back to where you started from....
~RJ~
