CoolJames
- Orlando, FL
If the ONLY way the manufacturer allows you to pull maintenance on the unit is to TURN IT OFF and pull it out of the closet then it won't be "energized" and the rule wouldn't apply anyway, would it?
Exactly, that's the point we are making, but he's stuck on the idea of having the small switch that's built inside the unit needs to have 36-inches in front of that. Makes no sense. The unit have to be disconnected at the source before anything can be done to it.
