dbuckley
- Canterbury, New Zealand
Ok, what you need is a metal plate installed where the HO wants to kick. Your local engineering shop will knock something up for you in fetching stainless steel. Lever microswitch behind plate. Install Micro PLC, and program it up so the kick toggles the disposal. Add a timer element in the program to switch the thing off after five minutes or whatever so if the dog or kid switches it on, it doesn't set the place on fire. Run the PLC off 24V (the PLC makers make a matching pretty PSU to the Micro PLC) and use a small contactor to switch the disposal. That way the microswitch and the control wiring is all low voltage.
Wite the bill and leave with the customer smiling at the $1200 they've just dropped for you to learn Micro PLC programming on his (her?) dime.
Custom installation on high end homes - nice work if you can get it
