Toe Kick Waste Disposal Switch!!
steelersman
Lake Ridge, VA
Because if there were accidents you would have been notified so I guess they are perfectly safe.:roll:
FWIW spelling master, it is 'from' not 'form' and 'disposals' not 'disposalls'. :D
Well it certainly isn't foolproof. I'm sure some people or kids have in the past managed to injure themselves with disposals, but it's impossible to make the entire world injury free.
steelersman
Lake Ridge, VA
sorry Bob. I was typing too fast. I got dyslexic with it. Disposall was a brand name I believe so that's why I used that one. :)
iwire
Massachusetts
But Decora switches aren't "Indicating" so the Nazi Code says we can't use it..:roll:
Bad day?
Anyway, you can use the decora as a control switch but you would need either an additional indicating switch or cord and plug to meet the disconnecting means requirement.
mxslick
SE Idaho
Bad day?
Nope, just bein sarcastic.. :D
Just flashback to a thread a while back with a good debate on use of Decoras on GD's. :D
benaround
Arizona
Greenlee has a floor sw. for their wire pulling equipment, it's $400+ and is industrial grade
momentary contact with cord. You can get the Plumber into this to pipe in the 120vac
solinoid to automaticlly run water into the GD when foot sw. is closed. Mount the foot sw.
far enough away from the sink so you could not reach into the GD while stepping on the
foot sw.
These people want to spend money, let them!!
480sparky
Iowegia
foot sw.
You can also get one similar to it at any tool store for about $30. I use one for use on a vac/blower when jetting conduits.
iwire
Massachusetts
"Indicating"? Why? What's the purpose if 'indicating'?
You lost me, part of the requirements of a switch used as a disconnecting means is that it is indicating.
A decora is not, a standard single pole switch is.
Unplug it. Done deal.
Of course ..... assuming it is cord and plug connected.
When I was doing dwelling units we never used cord and plug connections the GDs and DWs would be hard wired.
If I was doing them today I would probably go cord and plug connected.
steelersman
Lake Ridge, VA
Same here. I have never even seen one that was plugged in. And I've wired many a house, condo and apartment.
480sparky
Iowegia
The only hard-wired dispolsals I've ever seen are ones with NM right into them...... obviously done by hacks. I can't recall ever wiring one myslef that wasn't cord-n-plugged.
steelersman
Lake Ridge, VA
I am assuming that you are joking about the hack thing. But in case you aren't why would you consider it a hack job with NM right into the disposal? This is perfectly acceptible. The wall switch is the disconnecting means.
