stickboy1375
- Litchfield, CT
I may be wrong (again) but the SJO would be considered fixture wire and not my problem. Just like when I run a #8 to a 40 amp A/C unit and they now are coming with #10 pigtails already installed.
Never seen one like that. My first thought was that I would have a round outlet box. But the smallest that I could find is 3 1/2" and the 3 holes don't line up. Hmmmm?
'Suppose you could run it in the wall to a nearby switchbox.
If my wife sees this thread and wants a towel warmer I am sending you the bill.
Where did that come from? Bed bath and beyond? What are the specs?
If the unit is approved I probably would install it as the equipment is not under the NEC
Listed CSA with NRTL/C for use in the United States and Canada
Well If my wife came home with a $2885.00 towel warmer we would be in divorce court:lol:
Whenever I get an appliance with a blue neutral and brown hot I get nervous.
Wow, Is the house really that cold that they need a heated towel? For $2885 I could install a heater that would heat more than a towel...Might even turn the heat up a degree or two.:blink:
