jrsherbundy
New member
I recently had a question asked by a contractor on a job we designed in which we specified two "ground triads" for purposes of providing an adequate service entrance ground.  I wanted to search the Mike Holt Forums for relevant information.  I did find a concensus on service grounds, which is what the code requires, but I did see one response which really bothered me and shows a lack of understanding what adequate grounding is all about.  The poster's response was...."......Those are some scary answers. These people shouldn't be designing electrical systems if they think grounding electrodes have anything to do with OCPD operation."  I could not respond on that thread as it was closed, and while active, no one made any comment relative to the OCPD comment.  We should all remember that the lower the resistances are in the ground fault current return path, the higher the current will be and a higher current will operate the OCPD faster, thereby limiting system damage and perhaps better coordination with other ground fault protective devices.  This is just my two cents worth.
Jim Sherbundy, PE
Cleveland, Ohio
			Jim Sherbundy, PE
Cleveland, Ohio
