TOOL_5150
- bay area, ca
I have said many colorfull words while on a ladder working in a j-box on a live circuit and found that someone twisted all the wires so tight it looks like a # 2 cable. I was taking some pendant drops out of service a few weeks ago and everything was pre twisted, wire nutted and taped. I had no idea where the panelboard was so I decided to do this hot. After taking the 1/4" thick layer of tape off the wire nuts, as well as removing them I found that the wires were wrapped so tightly I just had to cut them all and re-strip the wires that were not being removed.
Holdng all the wires flush and installing a wire nut will make quite a good connection. I see no regular need to pre twist. Putting tape on the wire nuts drives me nuts. Theres no need for tape if you did step 1 correctly. Ususlly when I see that the wire nuts are taped, I quickly find out that it was done by an amature. [I do not mean to bash anyone here that tapes wire nuts] It it just most times when I go to fix a problem I find mistakes that anyone called an electrician would have known not to do.
~Matt
~Matt
