jwelectric
- North Carolina
Re: under-cabinet lights
The term direct connection appears in the 2005 code in 10 articles. The first hit is in 100 for lighting outlet and the last in 695 for fire pumps.
As I read each article I see that the intent of direct connect has to do with going straight to as in 695.4 (A) fire pumps and the ability to go straight to the line side of the power source supplying current for the pump.
695.4 (B) (1) allows overcurrent protection as long as it is rated to carry indefinitely the sum of the locked-rotor current of the fire pump motor(s) and the pressure maintenance pump motor(s) and the full-load current of the associated fire pump accessory equipment.
As outlined in the hand book this would be the same as directly connected with out overcurrent protection.
In 250.188 The grounding electrode to which the portable or mobile equipment??. shall be no direct connection between the grounding electrodes, such as buried pipe and fence, and so forth.
I take this as to mean not to be touching in any way.
I could go on with this as in 427.26 Isolation Transformer to insure that the heater is directly connected to an AC power source.
By the reading of these articles I interpret the term directly connected to mean going straight to.
It is also my belief that that when the code is referring to permanent wiring means it will come out and say permanent as in
Attachment Plug (Plug Cap) (Plug). A device that, by insertion in a receptacle, establishes a connection between the conductors of the attached flexible cord and the conductors connected permanently to the receptacle.
I can us a plug to directly connect a piece of equipment to the permanently connected conductors of a receptacle.
As to the receptacles that are in rooms other than kitchens, dinning, ect they are by the very definition given in table 220.12 lighting circuits. To carry this as far as to call the receptacles lighting outlets would be correct in theory.
These receptacles are part of the required lighting circuit and can be used for floor lamps, table lamps or attached overhead fixtures.
In 210.52 (B) we find the requirements for the small appliance circuits. We are told in 210.52 (B) (1) exception 1 that if we want we can add another receptacle and switch it for a light as long as we use the lighting circuit.
Being given this exception, we are told in 210.52 (B) (2) that we can have no other outlets on these small appliance circuits except a receptacle for a clock and a receptacle for a light in a gas range. Now if these forbidden outlets had to be boxes why in the world did they allow those receptacles?
Another thought to apply to this is the direct connection to an overhead florescent light fixture in the kitchen that has no box. Where is the lighting outlet? Would it not be the point at which it receives current?
Note that I used the term direct connection here to show the lack of a box.
Should the definition of a Luminaire describe a lamp holder only it would make this a lot easier to understand, but it doesn?t, it includes every thing including the cord cap.
Luminaire. A complete lighting unit consisting of a lamp or lamps together with the parts designed to distribute the light, to position and protect the lamps and ballast (where applicable), and to connect the lamps to the power supply.
A lighting outlet is any place that me, you, or anyone else intends to draw current for this luminaire as defined:
Lighting Outlet. An outlet intended for the direct connection of a lampholder, a luminaire (lighting fixture), or a pendant cord terminating in a lampholder.
Now I am going to the hospital to see my mom. Chew on that for a couple of hours and I promise I will be right back.
J Mike W
Cheif of Nothing
J Mike W
Cheif of Nothing
