Re: under-cabinet lights
Originally posted by jwelectric:
iwire April 30, 2005 06:20 PM
I can not agree with his read on this issue, IMO he is off the chart on this one. We all go there occasionally.
Which part do you not agree with?
I do not agree a lighting fixture is an lighting outlet.
I do not agree "permanently connected" has anything to do with an item being mechanically fastened in place.
I still can not see how you can twist this definition so badly
Lighting Outlet. An outlet intended for the direct connection of a lampholder, a luminaire (lighting fixture), or a pendant cord terminating in a lampholder.
How in the world do you figure a complete fixture, ballast, cord, plug, switch lampholders and enclosure is the lighting outlet.
Look at the first two words of the definition
An outlet
So we know immediately this is an outlet now look at the NEC definition of outlet.
Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
Thats it, the outlet 'stops' where the utilization equipment 'begins'.
It's that freaking simple!!!!!
Again with the utmost of respect I ask for anyone even the bullies to explain to me where that I am misunderstanding article 210.52 (B) and the definition of an outlet in article 100.
As I posted you must read the definition of lighting outlet then read the NEC definition of outlet.
You will see an outlet is a point on the wiring system at which current is taken to supply utilization equipment.
The light fixture
is the utilization equipment it is not the continuation of the outlet.
And so is saying that plugging a lighting fixture into an outlet means we have permanently connected a lighting outlet to the circuit.
You ask us to show you where this is allowed, there is no section that says we can. That is because there is nothing that says we can't.
I don't know how this could be clearer and I grow tied of discussing it with you.
All the lurkers here have that have followed this thread will have made up their minds one way or the other long ago and it is clear that you and I are not going to agree on this.
Bob
[ May 03, 2005, 05:35 PM: Message edited by: iwire ]
