pagestreet
New member
Q1 I am running a copper wire from the panel gnd bar to the main water pipe and onto 2 grounding rods 6ft appart. Does it matter if this is one continious line or can I run one line to the water pipe and a seperate line to the two grounding rods?
Q2. Iam bonding the hot and cold pipes at the water heater with the gas pipe on its load side. Do I connect this to the Gnd bar of my main panel?
