San -Brooke
- USA
The local utility is offering service to customers to install parking lot lighting. They are responsible for the installation of direct buried metal poles, they provide power and assume responsibility for general maintenance and charging a monthly flat fee. The problem is they are providing power by coming off a transformer on the pole and installing a locked disconnecting means and then feeding the lighting underground with a hot and neutral only and then driving a ground rod at each pole and running a #6 bare cu to the lug at the handhole from the ground rod. They are not getting an electrical inspection nor do they have a licensed electrician on site to supervise the installation in accordance with State Law. Since they are a utility they feel they are exempt from all of this.
Your thoughts?
Your thoughts?
