mechanical binding seems likely
drive starts motor
ramps to 15 Hz
current climbs as it ramps to 20 Hz
reaches a limit and backs off
like it is trying to start a high inertia load by increasing current/torque
but as rpm increases it hits a limit
the fact that it is always in 'accel' mode seems to confirm
especially since ramp time is only 2.5 sec
who aligned/coupled the pump?
use a laser?
shim everything,
check it after completed?
what is the motor speed? 1800, 3600?
is the vfd set up for the correct speed?
drive starts motor
ramps to 15 Hz
use a laser?
shim everything,
