Another C10
Electrical Contractor 1987 - present
- Southern Cal
- Electrician NEC 2020
people just love using cords it seems.This ran a floodlight mounted at the end of a porch
This is not necessarily an illegal application but there is a problem,I would assume it's split for one of the receptacles to be on a switch
Hint : Customer tells me some times the outlets work sometimes they don't, its the strangest thing he says ..
Hint: This should be the final one, the switch leg is typically which color.Hint : Customer tells me some times the outlets work sometimes they don't, its the strangest thing he says ..
I suppose the 2 hr rating is no longer valid.You can also click on a photo and then right click on a single image, insert it into a post then comment on it. Or you can do several at a time with comments before/after each photo.
I would say none of these images were licensed electricians, probably DIY handy persons.Do most of these pictures involve electrical contractors performing work
That's always a beauty, how does that even become a considered reality.
sorry testing...
So they daisy-chained the other receptacle(s) to a red switch leg instead of to a black hot wire at the top part of receptacle ?Hint: This should be the final one, the switch leg is typically which color. I guess 1 more hint is good, there is only 1 switched receptacle in this room.
I thought the split-wiring was obvious. Anything else?Hint :
Each wire facing you has a purpose once you determine that you will see.. If not I'll tell you.
Obviously again, the two blacks should be together and the red on the other receptacle half.Hint : Customer tells me some times the outlets work sometimes they don't, its the strangest thing he says ..
You got it, others may have as well ..Obviously again, the two blacks should be together and the red on the other receptacle half
