realolman said:I imagine it would be possible to do a job troubleshooting and replacing a large motor starter, pulling a batch of control wires , and hooking up some mag panel that wouldn't require much different screwdrivers and pliers than you'd use for anything else.![]()
Controls said:industrial
Definition
Anything having to do with the business of manufacturing products; excludes utility, transportation, and financial companies. ( found it on the internet)
Satcom made a few, very good points (IMO) about being qualified for industrial work. Also, need to remember to obey/play by the special rules of the industrial facilities, that changes, place to place. it is just not matter of showing up and doing the physical work that is involved.
bikeindy said:. . . . . I don't think anyone here would call themselves an industrial electrician just because they hung some lights in a warehouse.
bikeindy said:and having your company ISO 9000 certified doesn't mean you can troubleshoot a production line problem. It is a skill learned and then put to practice, I don't think anyone here would call themselves an industrial electrician just because they hung some lights in a warehouse.
emahler said:no...but when a company that ISO needs a new vendor, it tells them that you understand their needs....not just electrically....it's not necessary, but then according to some members here, neither is a license and insurance![]()
satcom said:When you wonder into industrial there is more then tools to consider, do you have the experience needed to troubleshoot complex systems, are you insured for industrial work, high voltage coverages, do you have the proper personal protection equipment, chance poles, other high voltage gear. Juat a bit more then having the tools.
Karl H said:I am an electrician. I work 90% Industrial.I'm not gonna split hairs here. Electricity is electricity.It needs a path in order to perform work.It could be a recept in a house,switch,motor,PLC, or whatever. As a electrician you need to always ask yourself,"What enviroment am I in,and what rules apply here?"If you don't know the rules,you need to learn, If you do know the rules complete the job and cash your check. If you don't know the rules and still complete the job and it fails ,prepare to lose money, and possibly get sued.
Definition
zog said:Stemming from brians post about van logos, what do you consider "Industrial"?
I believe it is impossible to do residential and industrial. Industrial is Steel mills, car plants, paper mills, mines, stuff like that.
MV cables, Basler relays, vacuum circuit breakers, 480V double ended-substations with draw out switchgear, in-house steam plants with power generation capabillity, emergency DG systems, 3000kVA 13.8kV to 480V transformers (Dry and liquid), etc....
That is what I think is industrial, buts I am interested to see what others call industrial.
IMO there is no way 1 guy can be compentent in residential and industrial, I know industrial systems, but would even think about doing residential work, it is apples and oranges.
I know your statemnents are generalizations, but it's not because any given person is only capable of one type of work, in my opinion. I believe it's more a matter of experience than anything else.zog said:I believe it is impossible to do residential and industrial. Industrial is Steel mills, car plants, paper mills, mines, stuff like that.
