chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
7) a
8) a (poorly worded, could be 3")
9) 8'-8'
9) 8'-8'
chris kennedy said:7) a
9) 8'-8'
wbalsam1 said:Please explain your comment re "3"...
I've PM'edyour grade
..........300.14 Where the opening to an outlet, junction, or switch point is less than 200 mm (8 in.) in any dimension, each conductor shall be long enough to extend at least 75 mm (3 in.) outside the opening.
chris kennedy said:..........
chris kennedy said:10) Typo 18 thhn?
11) a
12) b
chris kennedy said:10) b
Thanks for giving up the answer.:grin:
wbalsam1 said:Hey...you tricked me...![]()
wbalsam1 said:No typo. 18 awg thhn. :smile: Note: this test was based on the '99 NEC (Table 350-12), and 3/8" is no longer allowed. see 350.20 '05 NEC.
cadpoint said:Wouldn't that make the this question null / void out-right ? !
If you touched it under 05' (regional) code ? You can't let it stay in 3/8"
if there one bad circuit in the mass of circuits. Or in other words if it had to be serviced in any way it would have to be changed out and not left in a 3/8
I ran into this, take a test earlier this week, I didn't take any of them cause I assume it was closed book (and not mentioned either way)
Can you be sure to mention which year you might be working under, this type situation might make a smart person look average, or a average person look "other"... its just a thought.
I frankly Hate, "Oh yeah by the way, situations... "
wbalsam1 said:As a matter of fact, if I post any more here, I'll shape them for the '05. :smile:
Pierre C Belarge said:P.S. I just started highlighting my '08 NEC today....
chris kennedy said:That will be handy in 2023 when you adopt it.
I didn't know Pierre was from Wi.chris kennedy said:That will be handy in 2023 when you adopt it.
