JohnME said:So lemme get this straight, you take the power companys line side where it joins the tenants weatherhead and tap onto the poco's line for temp power?
Never heard of that being done, around here everyone has a generator.
77401 said:Wow... y'all sure do make it complicated.
Service change outs I disconnect the service drop first. Wire nut on a 15 foot piece if 14-2 with a handy box & duplex receptacle on the end. Never kept a count of how many times I've used this but its been in use since at least 1990 with out a problem.
infinity said:I wouldn't feel very comfortable using something that didn't have an OCPD between my power tools and the utility transformer.
We have to do it like that here, too. PoCo takes weeks to months to come out and put on a permanent splice. Since they know we are going to be tapping into their lines, it's a low priority for them.77401 said:The Transformer has fuses on the load side.
Cut the old off, put the new in & reconnect it. I won't leave my customers without power to wait on the POCO for a reconnect.
jeff43222 said:We have to do it like that here, too. PoCo takes weeks to months to come out and put on a permanent splice. Since they know we are going to be tapping into their lines, it's a low priority for them.
No, we don't go back (unless we left a jumper worth picking back up). The POCO finishes up and removes the old meter base and cables.jeff43222 said:So then you have to make a second trip to demo the old stuff after the PoCo comes out? The way I do them, I'm totally finished before the inspector or PoCo sees my work.
LarryFine said:No, we don't go back (unless we left a jumper worth picking back up). The POCO finishes up and removes the old meter base and cables.
LarryFine said:Here, except for co-ops, the POCO is responsible for everything on the line-side of the meter, from the lugs up. We're responsible for everything from the load lugs down.
I'm guessing the PoCo in Larry's area is responsible for the wiring on the line side of the meter. I have a hard time believing the PoCo is going to install a through-the-roof mast. Probably the EC installs the meter socket, mast, and weather head, but only installs wiring on the load side. Then I bet the PoCo comes in and puts their wires through the weather head, down the mast, and connects to the line side of the meter.77401 said:Wow!LarryFine said:Here, except for co-ops, the POCO is responsible for everything on the line-side of the meter, from the lugs up. We're responsible for everything from the load lugs down.
So they'll Install a thru the roof mast on an upgrade?
So does one put a 2/0 onto a 100amp meter socket?
They'll only remove stuff that's easy to yank, basically my temp wiring and the clamps. They aren't going to spend any time on demo.infinity said:I'm surprised. I can't imagine the local POCO removing anything past the connection to the weatherhead.
andycook said:In the San Francisco Bay Area, PG&E (the most common POCO, though some cities have their own power companies), the contractor supplies a combination meter base and panel. Though some contractors do their own disconnecting/re-connecting, I no longer do so.
I had an electrical service torn off a home by a felled tree. I called PG&E, reported the situation, pulled a permit, and installed a new service. I re-connected the incoming overhead lines, called for inspection (which passed), and called PG&E for a re-connection. The employee that came out for PG&E reported the customer for power theft. The customer was fined $500 (which I split with the customer). Ever since, I don't touch PG&E's meter or overhead lines. Unfortunately, it can take up to 5 days from disconnection to re-connection, but I can usually hook up a 2 pole 20amp w/ 12/3 romex to a neighbor for temporary power.
