I've seen plenty of things written in regulations that were far from clear. I'm sure you have too.120/240 is the IEEE/ANSI recognized methodology. It better not be misleading.
Your post #979:You need to go back and read the very first post, it clearly says "same utility transformer (ie. one winding)".
If we follow the industry standard interconnections, they can be interconnected as paralleled with X1&X3~X2&X4, series with X1~X2&X3~X4
synchronism: The state where connected alternating-current systems, machines, or a combination operate at the same frequency and where the phase angle displacement between voltages in them are constant, or vary about a steady and stable average value.
As I said, I had to post it for the professional honesty.Bingo!
Kudos to you for that.As I said, I had to post it for the professional honesty.
No. Or at least not without qualification about the differences in magnitude and phase.But to clarify things, would you say that it's OK to "... connect[-] alternating-current systems, machines, or a combination operate[d] at the same frequency and where the phase angle displacement between voltages in them are constant, or vary about a steady and stable average value" but don't have equal voltage magnitudes?
Not in mine.Apparently, "in-phase" and "in-sync" are colloquially synonymous in your branch of the industry.
Authoritative as it is, it still does not say what you claim. The phase is described as being the fractional portion of the period, not only part of the period. You have made an interpretation that does not agree with the rest of the industry members. They read the same definition, and then proceed to define "in-phase" in the way I have shown from many sources. If the industry sees phase and the subsequent definition of "in-phase" different from you, then it is obvious that the industry is not in agreement with your interpretation.Nevertheless the IEEE Std. 100 definition as cited is accurate and I believe both it and the source is still authoritative with respect to Instrumentation and Measurement.
Is that all?Seriously, we have been wrestling with a center tapped transformer output being; (2) voltages in-phase or (2) voltages out-of phase.
IEEE C57.12.80-2002 said:3.423 single-phase circuit: An alternating-current circuit consisting of two or three intentionally interrelated conductors that enter (or leave) a delimited region at two or three terminals of entry. If the circuit consists of two conductors, it is intended to be so energized that, in the steady state, the voltage between the two terminals of entry is an alternating voltage. If the circuit consists of three conductors, it is intended to be so energized that, in steady state, the alternating voltages between any two terminals of entry have the same period and are in phase or in phase opposition.
Please quote the definition for "characteristic phase" from IEEE Std 100.Did you read my response to your follow-up (Post 1221)? I did say the currents don't need to be - I didn't say they weren't; in fact, they probably are. However, the secondary current's behavior isn't what determines whether the transformer secondary voltages have the same characteristic phase and the phase characteristic of transformer secondary voltages isn't dependent on the are measurement technique. If the transformer secondary voltages have the same characteristic phase (which they do - which, in fact, they must) it's quite reasonable to describe the system as single-phase (which it is). QED.
Please review post 888 before we go another round. The definition of phase in that Post was actually supplied by rattus but, for the purposes of this discussion, it is compatible with the IEEE Std. 100 definition above.
We must measure all voltages with respect to a common reference
Has nothing to do with an oscilloscope. To compare voltages, we have to have a common reference. We all know this.Where is that written?
Oh, that's right. Your oscilloscope is limited in its capabilities.
I appreciate you posted definitonof synchronous that are compatible with Post 888 - even if it had to come from a "computing" source.
There are two ways to handle this.
For me I just accept 'because we do'
The other way takes 600 forum posts.
Says who? You are confusing a common node with a common reference point for all voltages. This is wrong and professionally dishonest.Has nothing to do with an oscilloscope. To compare voltages, we have to have a common reference. We all know this.
I may have "cheated" on you; I revised the question to only include magnitude since polarity is implied by "phase angle". Magnitude seems to elude consideration - even though we both know it's a critical consideration in most cases. But I'm pretty certain your answer would have been the same.No. Or at least not without qualification about the differences in magnitude and phase.
Excellent! Then we have synchronism out of the way, so let's get back to phase - where neither magnitude nor polarity are necessary to consider. Would you respond directly to Post 1241?Not in mine.
Why bother with a definition of phase ...
And with that response, ...
I said I used "in phase" like our industry does. You responded that it was technically incorrect, industry or not, and did not apply to a technical discussion. I replied that the sources were mainly used in the technical arena. In fact, most are used in teaching and how much more technical does it get than that?
Wikipedia provided by Bob said:A transformer supplying a 3-wire distribution system has a single-phase input (primary) winding. The output (secondary) winding is center-tapped and the center tap connected to a grounded neutral. This 3-wire system is common in countries with a standard phase-neutral voltage of 120 V. In this case, the transformer voltage is 120 V on either side of the center tap, giving 240 V between the two live conductors, shown as V1 and V2 in Fig. 1. The two outputs are properly called "legs", not "phases".
Except I wasn't at that time.Again, in response to your talking about using one voltage in two ways at the same time.
Didn't claim they were. Suggested you expand them.Weren't my experiments. These were in the 1860's.
Since you need help on this. http://en.wikipedia.org/wiki/Skin_effectJust more electrical theory you don't understand. ...
Why the primary side? Why not the secondary side where all the debate is? Why sidetrack the discussion? What would you call connecting A to a point half way between A and N? Halfway between N and B? To B? Your primary short is of course the obvious phase-to-phase short but has nothing to do with the secondary. Any such connections on the secondary are a simple shorted coil. We often jokingly call the heaters.What would you call two ungrounded conductors on the primary side being shorted?
Connecting the two ends is how we get a light bulb or a heater. AC or DC makes no difference. You have a potential difference between the points. It doesn't matter which two points on the coil you short. It doesn't have to cross the neutral to spark. They don't have to be out of phase. Just at different potentials.... Can you connect the two outer ends of a center tapped transformer together and have essentially no circulating current, or do you get big sparks? No sparks and the coils are "in-phase". No meters, no scopes, just a simple experiment.
With that, you wormed your way back into my good graces :thumbsup: - Of course, "my good graces" and whatever the local going rate is will only get you a cup of Starbucks, but I genuinely appreciate it....
Sorry. Did sound bad...
I did.Would you respond directly to Post 1241?
I apologize for missing it.I did.
Post #1245.
