Tulsa Electrician
- Tulsa
- Electrician
I see I used the incorrect code reference. 408.40 is the one I wanted to state.I would think this is two different in items.
480.40 grounding of panle boards.
Sorry for that.
It says in part " Where the panel board is used with nonmetallic raceway or cable or where separate equipment grounding conductors are provided, a terminal bar for the equipment grounding conductors shall be secured inside the cabinet. The terminal bar shall be bonded to the cabinet and panel board frame, if of metal; other wise it shall be connected to the equipment grounding conductor that is run with conductors feeding the panel board."
If I'm understanding correctly this requires a bar. This bar must be bonded to the enclosure if metal.
Then the attachment of this bar must meet bonding requirements.
So if a terminal bar not a lug is used I do see where it can be bolted as long as it is installed according.
250.4 (A) (5)
250.12
250.148 ( metal boxes (C))
As far as the bar goes it can be several configurations.
For this case a load center it would be the most common available from the mfg of that load center.
Then we have other types that lugs can be attached to however still a bar. Case in point a grounding buss bar which is bolted to the enclosure inside switch gear etc.
So based on that is why I say I would not do that. I believe A single lug should not be attached to the back of the can because there is not a large enough hole on equipment grounding terminal bar. Instead use the correct one made for the equipment and the equipment grounding bar if a larger conductor is required. In this case an add a lug or change the bar out with a one that has a larger lug on it.
I can personally say I have seen this a lug added to back of a can and in most cases after the wire had been added is was loose and not tight or more than one wire was under the lug. Makes for a poor installation.
I would also say how would you ever tighten it back up using the bolt and nut if you can not get to the bolt head after panel installation. If this load center in a wall. A loose lug is not a low impedance path. A loose nut and bolt does not have two threads in contact with the enclosure. However it does have a nut.
