The technique of using parallel thread or adjusting the depth or length of the threads to get things to fit reminds me of the parable of the Fox and the Cat. The Fox had many tricks to avoid the dogs, but the Cat only had one. As the Fox was explaining the various tricks to the the Cat, the dogs suddenly arrived on their trail. The Cat used the only trick it knew, climbing a tree. The Fox, while deciding which trick to use, was overtaken by the dogs.
Sometimes you can use an adjustable threader and do Fox tricks (parallel pipe, depth of thread, length of thread). Sometimes you only have a manual threader and can only do Cat tricks (length of pipe and maybe length of thread - it can get tough with larger sizes to keep going past a standard, full thread).
Adjusting the length of pipe while threading a standard, tapered length is always available. I'm going to stick with it.
