infinity said:It also depends on where you are and what code cycle your jurisdiction follows. Around here the use of AFCI devices is optional.
danam96 said:If I change a receptacle in an existing home, do I have to replace it with an AFCI if it is in a bedroom? Or can I replace with regular duplex?
No need to install an AFCI OCPD, if you are not installing a new bedroom circuit.
Question: Is there an AFCI receptacle??
Minuteman said:Trevor, you can get AFCI devices? I thought that AFCI only come in OCP right now.
The wording is, essentially, any new outlet in a bedroom gets AFCI protection.cpal said:This might be a good time to raise the question as to whether an extension of an of an existing bed room branch circuit will require the installation of an afci
resistance said:Yet, the rules will apply if a new bedroom circuit is installed.
It's the installation of the OUTLET that makes a circuit AFCI. . .210.12 Arc-Fault Circuit-Interrupter Protection
(B) Dwelling Unit Bedrooms All 120-volt, single phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit bedrooms shall be protected by a listed arc-fault circuit interrupter, combination type installed to provide protection of the branch circuit.
resistance said:what's your definition of Outlet. Just wondering! Thanks! Great insight!
Quite simply the Article 100 language attached to Outlet definition.resistance said:what's your definition of Outlet.
