McDowellb said:Agian, you have missed the point. The point is that GFCI's ONLY came in breaker form back in the dark ages. Just like the AFCI's now.
I didn't miss the point, I understand that once upon a time, back in the dim mists of antiquity, about the time the meteor killed off the dinosaurs, GFCI's were only breakers. You have attempted to move the point to ignore the fact that your statement was incorrect. Adding an outlet in a bathroom may or may not require GFCI. It depends on whether or not the outlet is a receptacle.
AFAIK, the bathroom GFCI requirement has always been at the device level, requiring bathroom receptacles to have protection. From it's inception, the bedroom AFCI has always been at the branch circuit level, initially requiring the branch circuit(s) serving bedroom receptacles to have AFCI protection, now requiring the circuit(s) serving all bedroom outlets to have AFCI. I could certainly be wrong, won't be the first time.
The fact that the technology 30 years ago required a CB to provide GFCI protection to the bathroom receptacles, and that the NEC previously required branch circuit protection for bedroom receptacles, effectively mandating an AFCI CB, is an interesting footnote. None of it is relavent to the OP's issue, which is confined to what is allowed when adding to an existing bedroom circuit today.
Today in my jurisdiction, if I were to add an outlet, any outlet, in a bedroom the inspector will require that the CB serving that branch circuit be replaced with an AFCI breaker. Certainly not the case for GFCI in bathrooms, and it never was.
Now, I have a question for all: What, exactly, did the 1975 NEC require with regard to GFCI in a bathroom?
