resistance
- WA
I've had my debate on the definition of the word "outlet", and it's usage. The debate was never ending. I'm with you on your definition Al. Yet, lets keep this secret! LOL!
resistance said:********
I do not believe extending a branch circuit (installed before the AFCI requirment--in some juridictions) falls under the AFCI requirements. Yet, the rules will apply if a new bedroom circuit is installed. Just something to think about:Extending a branch circuit that was installed as multi-circuit. (before the AFCI).
McDowellb said:Remember that an outlet for a switch does not require AFCI protection.
Yes the outlet would have to be protected. But if there is a switch in the bedroom that is on a different circuit that controls a light outside, then AFCI protection is not required.cpal said:Yes, but if the switch controls a lighting outlet or switched receptacle in a bed room it will need to be AFCI. Yes / No????
Charlie
McDowellb said:Attack of the killer "B'S" is back. Hello roger!
I say no.cpal said:This might be a good time to raise the question as to weither an extension of an of an existing bed room branch circuit will require the installation of an afci
I agree.resistance said:I do not believe extending a branch circuit (installed before the AFCI requirment--in some juridictions) falls under the AFCI requirements. Yet, the rules will apply if a new bedroom circuit is installed.
I disagree.al hildenbrand said:It's the installation of the OUTLET that makes a circuit AFCI. . .
I agree.resistance said:Yet, to add a receptacle should not require a person to make the "circuit" AFCI protected.
So your take of:LarryFine said:As I see it, this section addresses the installation of branch circuits, not receptacle outlets.
.After all, this is Art. 210, not Art. 406. If we're installing a branch circuit, 210.12 applies.
Charlie,cpal said:but I am curious. How many other jurisdictions have requirements that would impact a circuit extension such as we have been discussing?
. . .The board of electricity will not require AFCI protection on existing branch circuits unless they are extended into or within a bedroom after January 1, 2002. An example of this situation is when the electrical service is changed and no branch circuits are extended into or within existing bedroom(s).
And we're talking about "outlets" not receptacles. . .LarryFine said:not receptacle outlets.
al hildenbrand said:Charlie,
The State of Minnesota Electrical Licensing and Inspections, under the former name of the Board of Electricity, published in its Fall 2001 newsletter that
Yes. If the "outlet" is new and inside the bedroom, and the supply is an extension of an existing circuit, then that existing circuit must have AFCI when I'm done or my AHJ will tell me to go back and add the AFCI.cpal said:It does appear that if a circuit is extended into the bedroom area you require AF is that correct?
al hildenbrand said:If 210 is only about branch circuits, what is all that language in 210 on "Required Outlets"?
Hey, someone has to take the other side, or we won't have a chance of hitting 10 pages. Plus, if I agree with you, I'll have to install an AFCI when I add an outlet.al hildenbrand said:And we're talking about "outlets" not receptacles. . .
