mdshunk said:
Curious about 2 things.
- Where are you getting listed cover plates in wood?
- How does your inspector handle the issue that your receptacles aren't at least flush with the cover?
Nice work, and I'm not picking at nits. I am genuinely curious to know.
What inspector? This place was so far out in the sticks, there's no inspectors. :smile:
I've never had an issue with the recep not being flush. They're thin enough as it is, plus there's a routed edge on the inside that reduces the thickness even more.
This is the only log home I've done where the owner wanted wood covers. So truth be told, i never checked for a listing (yea, go ahead....kick me while I'm down now!). But I got them at the local Big Blue store, so next time I go there, I'll check.
Krim said:
Now sparky , will you tell us if you had to cut the profile and the holes in the timbers or did the carpenters do it ahead of time for you and part deux how the heck did you run the wiring throughout the house , did the logs have to be hollowed out to accomodate that aspect prior to being set into place during the construction ?
Inquiring minds want to know .
Carl
I work closely with the logging crews when they start setting the walls. The two builders I have who do log homes don't do full-timber jobs.... they're called D-logs, based on their profile, so the logs (yes, they are logs, not milled lumber) are in reality a veneer. They're flat on the back and screwed to the studs. I don't set a box during rough-in, I just leave a tail of wire long enough to work with.
I give the log crew a 1-gang, 2-gang 3-gang and 4-gang boxes so they know how big they need to cut the logs. I mark what gang of box I need for each cut-out on the stud next to the wire tail in case I'm not there when they put up the logs.
Sometimes they're aren't perfect, and I need to get out a sawzall, but that's only 2 or 3 boxes in the whole house, so I don't complain.
On this house, there was one guy on the log crew who would use a chainsaw to flatten out the log around the box. He did it freehand. It was amazing to watch him do that... I would not have the stability or patience to attempt it.
stickboy1375 said:
Alot of the wood plates I install have a metal backing to them.
Yes, I remember they all had metal on the back.
