- Massachusetts
Bob , is it concealed or not ? Simple yes or no
Yes it would be concealed.
Yes the NEC allows it.
I see panels concealed by calendars and stuff all the time.
Got to agree with you on this ,yes concealed is legal. But would you want to plow thru hundreds of square feet of insulation trying to find a junction box ? As an inspector i would want it flaged in some manner.
a NIMIZ: Not In My Inspection Zone.So you would be the kind of inspector that you complain about here. Just make things up on the spot.
Never look forward to it but it is just one of the things we have to do. Boxes can be tough to find even if they are not covered up.But would you want to plow thru hundreds of square feet of insulation trying to find a junction box ?
That would be great, but I have yet to find them nicely flagged. I have never flagged the ones I put in either (guilty as charged).As an inspector i would want it flagged in some manner.
Would the insulation really have to be removed?? disturbed yes ,.removed? I've found more than one without removing the insulation .
Sorry I still see this as a violation and would turn it down.
This is so easy I don?t understand why everyone don?t see it.
If the insulation is over the opening of the box and I shove it around to make an opening then I must have moved the insulation from its original position to another spot or in other words I removed the insulation from over the box something that 314.29 says I shouldn?t have to do.
Take a look at 314.29…….so that the wiring contained in them can be rendered accessible without removing any part of the building….
Seeing that the insulation in the attic is required by the building code would the insulation be part of the building?
In my opinion the insulation is part of the building therefore the box would be in violation if below the insulation.
No more boxes behind doors! :grin:This is so easy I don?t understand why everyone don?t see it.
Man! I've got a few bids I need to re-work! :grin:So the NEC, which is part of the building codes, requires covers on my switches and outlets. Now I have a violation, right?
