Digiacog
- Boulder, CO USA
Hi Folks, Colorado solar guy here.
First time posting here, and my apologies if this is a dead horse type question: Does the Line Side Tap Neutral (Bonded in the Fused disconnect) count as GEC to main panel, or do I need to run a GEC to my fused disco even though my Neutral is accomplishing the same bond? Both my egc/GEC and Neutral are #6 AWG THWN-2
I've had an Estes Park inspector call me out on "paralleled conductors" and made me remove the additional EGC/GEC wire between fused disco and the Main Service Panel. (He also said I could leave the paralleled conductors if I upgraded them to 1/0 (hah!))
I've had a Boulder inspector ask me to add a #6 GEC from the fused disconnect's ground bar and crimp it to the GEC, a foot away from where it is landed next to the Neutral in the main panel!
So, which inspector is right?:? Is 1 wire Sufficient or do I need to run both the Neutral and a separate GEC? What are the benefits of each way? or are they functionally the same, and I should just suck it up and do what each AHJ wants instead of trying to get them on the same page?
