If you can't find the problem, whatever it might be, you just don't own the right test equipment yet.
You're sure right about that. I basicly approach the tougher problems as though everything everyone has told me is a lie. Maybe not the case most times, but as you rightly point out, people will relate their own incorrect conclusions and assumptions as part of the reported symptoms. The famous one is 'the breaker is bad'.petersonra said:Often you get reports that seem to be more of a conclusion from the guy reporting them then an accurate relaying of the symptoms.
mdshunk said:You're sure right about that. I basicly approach the tougher problems as though everything everyone has told me is a lie. Maybe not the case most times, but as you rightly point out, people will relate their own incorrect conclusions and assumptions as part of the reported symptoms. The famous one is 'the breaker is bad'.
Reminds me of an old man electrician that I used to work with that would put a row of strip lights on a 60 amp breaker to make the ballast that was tripping the 20 amp breaker declare itself. Yikes!acrwc10 said:Years ago I was at the supply house and an HVAC guy kept comming in and buying the same fuse about every 20 minutes. He would put them in a roof top unit turn it on, it would blow the fuse right away, then he would come back and buy more fuses.
jason said:This is a fun thread.
The most aggravating part of troubleshooting IMO is the person who you're doing the work for isnt being honest with you. This happens most when the person you're doing the work for isnt paying the bill.
electricguy61 said:Guess what? It had never been tightened. I suppose that when under a large load, it would heat up and cause the problem.
It taught me a good lesson: always check the tightness of connections.
How about those who stand so close to you the whole time, you are afraid to bump right into them if you make a fast move? e/me57 said:Sometime even when they are paying the bill..... I come across this a lot. And simular situations....
Joe Home-owner: "It just stopped working the other day..."
You open the boxes of the circuit and notice that there was NO WAY IT COULD HAVE!
As you're fixing it, 'Sue - Joe's wife' slips you the news that it 'just stopped working' after Joe messed with it.....
That's a great idea, I will have to tell everyone at my shop about it. e/m.acrwc10 said:When I torque down the lugs in a panel I take a marker and put a line across the two parts of the lug. This way I can tell at a glance if it was done and if someone has messed with the lug after I was there.
Wow. That was a few years ago.
Basically still a mystery.
Around that time I was involved with a new piece of recording equipment. The utility also hired a consultant who was a former employee and renound for solving tricky problems. When the $8000 voltage recorder measured a collapse of single phase voltage with no corresponding change in phase to phase voltages, the utility took the position that although we didn't know what was causing the problem, it wasn't coming from the utility supply.
The customer didn't like the answer and went to the regulatory board with a complaint. The regulatory board felt that the utility should be considered the experts on these matters, and more effort should be undertaken to prove our innocence. We were given approval to buy a cadillac, real time Dranetz signature system. This was an 8 channel system installed basically permanently at the location, connected to a phone line. The voltage was measured at the overhead distribution transformers outside the building, and at the customer supply inside the building with all channels fed into a box connected to a phone line.
Whenever the customer experienced a problem, the recordings showed no corresponding activity on the utility side.
In the meantime, the dentist who had his practice in the basement got tired of the whole situation and moved his practice. Since then, things have been pretty quiet. The equipment is still recording, but the complaints are much fewer in frequency.
So I guess we will never know if the problem is solved, or just went away with the dentist, or is simply dormant and will reappear for a future generation of engineers to scratch their heads over.
The End. Or is it?
Intermittant is the dirtiest word in the English language.mdshunk said:The short answer is 'Yes'. Intermittant problems buck the heck out of people.
When you talk about motion control systems and PLC, I've seen some weird stuff happen for no clear reason, but it was resolvable. I've seen I/O's that the ladder logic on the laptop showed were open or closed, but the acutal output was completely the opposite (bad output card). I've seen G-code get spontaneously corrupted all by itself with no human intervention.iaov said:I worked for years in a highly automated industrial enviroment. Problems often came and went while we sat and stared at the ladder logic.
Reminds me of the commercial (forget for what) that went like this: Honey do you know what this switch is for? No, I have never used it. Well he man turns it on and off repeatedly, only to lower and raise neighbor's garage door as she is backing her car out of the garage! I never thought it could happen in real life ! e/m.jason said:I have another one.
I went on a service call once where the game room was completely without power. The game room was once a garage or carport that later was enclosed (although this really doesnt matter).
So I get up in the attic to find a feed to the room. I found it, traced it all the way to the other end of the house. Seriously, it was as far on the other end of the house as you could get. It went down into a light switch by the front door. I turned one the switches, a 4 gang box, and the game room has power again.
The home owner told me they bought the house 11 years ago and never knew what that switch went to. They just always left it on and didnt know it was off then. said they had a party recently and someone must have turned it off. I figure at one time there was a flood light, maybe?, and someone used that switch leg as power to the newly enclosed game room.
11 years, and they didnt have a clue.
Energy-Miser said:Reminds me of the commercial (forget for what) that went like this: Honey do you know what this switch is for? No, I have never used it. Well he man turns it on and off repeatedly, only to lower and raise neighbor's garage door as she is backing her car out of the garage! I never thought it could happen in real life ! e/m.
