Mike
I'm still waiting for an answer to my previous questions. As a teacher you should be able to explain yourself.
quoting jwelectric
If the fear is about the grounded (neutral) conductor that is present in the fixture and this conductor is part of a multiwire circuit would the equipment grounding conductor be as dangerous? Remember that the equipment grounded conductor is tied to the grounded (neutral) somewhere in the system. One conductor will be carring as much current as the other.
end quote
Did you say you were a teacher ?
Do you know that you posted that the equipment ground and the neutral "One conductor will be carrying as much current as the other" ?
Did you really mean to say that ?
Do you think that 2 wires that are connected together automatically carry the same current ?
David
quoting jwelectric
end quote
David
