electricmanscott
- Boston, MA
- Massachusetts Master Electrician, one man show.
Did some misc wiring for a guy. Noticed new pool installation. Guy inquires about having a switch for the pump inside the house. I suggest timer.
Scope out the setup and find, 20A breaker feeding #14 nm through basement to j box. UF from J box to pool pump receptacle. Twistlock receptacle with no GFI protection. Convienience receptacle 4 feet from pool. #18 insulated solid attached to bonding lug run to pool etc.
I counted 10 violations and explained them to the guy.
I let him know that if he wanted the timer installed I'd only do it if I rewired the entire setup properly. His response was "well it's working fine so I probably won't worry about it".
Doubt I'll ever hear from them again.
