I have called him and 2moro or the day after 2moro he will come.
Come on HE. Lets not start these short cuts with the english language.
I think the clearest answer that I got was from Steve66. Does anyone disagree with what he said? I'll try not to ask anymore "dumb" questions...:roll:
I saw that you had the current leading the voltage by 90 deg. I figured it was just a mistype.Well on my end it is past tense...
Yes, of course that would be the one that explodes....And, it is actually at the current's zero crossings that impedance goes off the chart (a fold in the whole space-time contiuum, because it is both positive and negative infinity at the same time)...
It is an interesting mathematical model. However, you may be the only one in the world that uses it. Most everyone else, when dealing with sinusiods, uses:...In a purely passive RCL circuit, Z is always 0 when V is 0, but I may be a non-zero value
Hmmm... don't see it. Current lags voltage on both pages.I saw that you had the current leading the voltage by 90 deg. I figured it was just a mistype.
I agree. It is an interesting mathematical model. But no, I do not use it as such. It is just interesting, and the purpose for presenting it, to see by graphical representation how the impedance varies, along with it going negative (returning the "absorbed" power back to the source). I thought the graphical presentation would help some who are not so versed in the math to better imagine what is happening. I don't know about you, but I can't visualize the impedance waveforms using the proper equations.It is an interesting mathematical model. However, you may be the only one in the world that uses it. ...
The model you are using is, well, pretty unusable. And I thinking you already knew all of this.
Absolutely true - don't know what I was thinking.Hmmm... don't see it. Current lags voltage on both pages. ...
Yeah, that is the interesting part. Looking at it from the point of view that the impedance changes depending on which part of the cycle the current is in -- that's a new concept for me.... It is just interesting, and the purpose for presenting it, to see by graphical representation how the impedance varies, along with it going negative (returning the "absorbed" power back to the source). ...
I don't know what "impedance waveforms" are (is?).... I don't know about you, but I can't visualize the impedance waveforms using the proper equations.
Perhaps...
...but what I see missing from practically all explanations is the fact that reactance impedance is not steady state as it appears to be. That is, when doing the basic Xrcl component equations, one is left with an impression that impedance is constant in the instantaneous domain. It is not.
Attached is a simple pdf I whipped up with two pages giving a visual representation of what happens to impedance, with a sinusoidal voltage applied across an inductor's terminals. The first page is with an ideal inductor, and the second with a real inductor, such as a typical wire wound coil.
Not really a new concept... just that your conventional education keeps you thinking in the box. You are permitted to think outside the box, just in case you didn't know...
...and this fixed Z is to instantaneous Z as 120VAC is to instantaneous voltage.The view that I would be more comfortable with is:
The impedance is fixed: Z = jwL and that causes the current to lag the voltage.
The only problem here is that your stated premise has the phase shift as the cause. It is not. Phase shift is the effect.The physical property causing the phase shift is the current builds a magnetic field in the inductor and that stores energy. Energy is pumped into the inductor magnetic field when the current is increasing. And when the current decreases, the magnetic field collapses, and dumps the energy back into the system. And it takes a phase shift to make this happen.
Well, I guess technically they are not waveforms.I don't know what "impedance waveforms" are (is?).
Sorry, but you are getting into my too-rusty-to-follow area. So what do they look like?But if I apply Euler's formula and make them vectors (or rotating vectors, or phasors - what ever term you like) then I can see them.
Thx...No question, your pictures look prettier than mine
Nope. Not missing any facts... but I'll be modest and say I'm open to correction. In the meantime, please review my graphs. In both instances the plots indicate an input voltage present when current is zero.Smart:
I think you are missing the fact that inductors and capacitors can have a voltage across them even when the circuit current is zero.
Indeterminate by the simple math. But taking before and after into account, and the rate of change of the impedance, all indications have the impedance at plus and minus infinity when current is zero.Say for example that your graph shows input voltage vs. current for a single inductor. When the input voltage is max., and the current is zero, the voltage across the inductor is equal and opposite to the input voltage. So the net voltage around the circuit is zero. If you tried to calculate an impedence, you would have 0 Volts/0 Amps = Z, which would be indeterminate.
Since it apparently isn't readily apparent to you, I already know thisIts different than a resistor, which would always have 0 volts across it when the current is zero.
I explained the advantage earlier. It is not meant to represent some new math model to work by. Rather it is simply a graphical representation.I guess you could say that your impedence (maybe we should call it an instantaneous impedence) also includes the voltage developed across that impedence. But like Cold, I don't see much advantage in looking at this instantaneous impedence. I don't see an advantage because the value of this instantaneous impedence also depends on the past history of current or voltage - how much a capacitor has charged, or how much energy is stored in the magentic field of a inductor.
Please show me a plot of the impedance you refer to...At any rate, its certainly not the same impedence that most people are used to dealing with.
I don't think you are missing any facts either. You get it. No correction from me.Nope. Not missing any facts... but I'll be modest and say I'm open to correction. ...
...I explained the advantage earlier (of the model of an inductor having variable, real, impedance, and not using the concept of reactive components - cf) It is not meant to represent some new math model to work by. Rather it is simply a graphical representation. ..
Ouch - hang on a minute while I pull the knife out of my back.Not really a new concept... just that your conventional education keeps you thinking in the box. ....
Okay. However, as I stated in an earlier post, I think I understand your model. You are exciting an inductor with a sinusiod, measuring the instantaneous voltage and current. The measured values are real (scalar)values. There are no vector components, the concept of reactive impedance is ignored. Then dividing the measured voltage by the measured current, and calling the result the inductor impedance. Isn't that your model?...As a consolation, I'll get around to aligning in the box with outside the box here in a little bit ...
I have no clue as to what this means. To get the RMS voltage, one integrates the square of the instantaneous voltage over one period and then takes the square root. I have no clue as to how that applies to what you are doing to the inductive impedance....and this fixed Z is to instantaneous Z as 120VAC is to instantaneous voltage. ...
That is not a problem for me. I'm okay anyway you want this one....The only problem here is that your stated premise has the phase shift as the cause. It is not. Phase shift is the effect. ...
I'll let this analogy go. You have conotations of negative resistance and inductors as power sources. There is steadystate sinusiod mixed with sinusiod initial conditions, DC steady state, DC initial conditions. And a minor physics flaw....Let's use an analogy of connecting two identical batteries in parallel. ...
...In the case of the inductor, on the application of a voltage across its terminals, it instaneous creates a counter emf to oppose current flow, essentially the same as the two identical battery scenario above. Note this is the start of the phase shift, because current is at zero when the voltage is applied. If the voltage were maintained steady state, the counter emf would subside because there is no current to maintain the field (the physical characterictic of an inductor that you speak of)... for it is the change in voltage which creates the counter emf. Therefore, the counter emf subsides, and current flows. This is comparable to the inductor being the second battery having a lesser charge....
...At any rate, its certainly not the same impedence that most people are used to dealing with. ...
...Please show me a plot of the impedance you refer to...
I do not. Pretty basic, and straight to the point. All the calculation stuff isn't necessary to understand the concept![]()
...But if I apply Euler's formula and make them vectors ...
Uhh .... My comment didn't fit the discussion. Please let this one go. Sorry...
Sorry, but you are getting into my too-rusty-to-follow area. ...
(rotfl)That may be the case, but all the understanding stands on a pretty weak ground if you can't prove it by 'calculations'.
Does any one disagree with this?!
Part one
Part 2
Perhaps it will help someone understand what happens without getting into all the [unnecessarily] complex calculations. Perhaps in time you'll see it. I don't think you can now because you already have a firm grasp of the complex side of the phenomenon. I believe it very difficult to be retrogressive intentionally and without good cause... and this is what you are exhibitingYou have a valid model. I just don't know what one could use it for.
Yes, I disagree... in a sense.That may be the case, but all the understanding stands on a pretty weak ground if you can't prove it by 'calculations'.
(rotfl)
I've got this picture in my head of you standing there, fists all bunched up, adversarial look, defending your line in the sand.:grin:
Gives me a nearly uncontrollable urge to kick sand all over your line:roll:
(laughing to hard to type)
Well, in one specific area, you are right.
In two other specific areas, you are wrong
So, two to one, I disagree.
cf
This gets into the realm of the philosophical, IMO. Are instantaneous values of impedance important in an AC environment, anyway, and/or do they even have any real meaning?I think it is time to let this go, if you have no objections.
My intent was simple, but you want to take it to the complex... in more ways than one. You want to exhibit being able to think outside the box, but yet to explain any concept of the phenomenon, you immediately resort to the complex calculations (see middle of Part 2). What is so hard to understand about Z = V/I and plotting it? (That's a rhetorical question, btw)
Proof is in empirical evidence.
Calculations are just a means to determine values when empirical evidence is not available.
If the calculations don't match the empirical evidence, what good are the calculations?
Granted we have a fair or better understanding of electrical phenomenon, and calculations to match, but someone first had to compare the calculation results to empirical evidence so as to affirm the validity.
Nice pun...My intent was simple, but you want to take it to the complex... in more ways than one. ...
