nicholaaaas
- Baltimore
PF= Cos(Tan^-1(VARS/True Power))
I agree... So trying to convince me of something differnet than what I observed yet do not adhere to is a waste of your time... IMO. ...
Using the current english definition of "instantaneous", this statement is wrong. Please note that I am certainly not trying to convinince you of this fact.... If I tell you I had a reactive load for which I measured 56V and 3A at one instant, can you tell me the real and reactive power portions of the current? No you cannot. ... .
Yor're right. In fact, for this thread I vote for pig latin... I didn't see any guidelines that said I had to restrict my usage of the english language...
Is this a pun on "Dirk Gently's Holistic Detective Agency". If it is, it's a good one....I embody knowledge as a whole, and use it as such. ...
For this I am horrible apologetic. In my defence, I can only say that adhering to the known body of the laws of God and physics that have been built upon for the last 350 years, would never have occured to me as asking you to lessen yourself. I would never want you to do that.... I shall not lessen myself for the likes of others. ...
Iyay inkthay Iyay dooday.:grin:...Sorry if you can't understand...
What about it is wrong????......
Using the current english definition of "instantaneous", this statement is wrong. Please note that I am certainly not trying to convinince you of this fact.Smart $ said:... If I tell you I had a reactive load for which I measured 56V and 3A at one instant, can you tell me the real and reactive power portions of the current? No you cannot. ... .
Merriam-Webster Collegiate? Dictionary
in?stan?ta?neous
1 : done, occurring, or acting without any perceptible duration of time <death was instantaneous>
2 : done without any delay being purposely introduced <took instantaneous action to correct the abuse>
3 : occurring or present at a particular instant <instantaneous velocity>
Not a pun at all... it's interesting though that you found it entertaining.Is this a pun on "Dirk Gently's Holistic Detective Agency". If it is, it's a good one.
I do believe you would not do it... knowingly. But sometimes people's eyes have to be opened for them. And your defense is pretty weak considering my offense has essentially the same backgroundFor this I am horrible apologetic. In my defence, I can only say that adhering to the known body of the laws of God and physics that have been built upon for the last 350 years, would never have occured to me as asking you to lessen yourself. I would never want you to do that.
[B said:Smart $][/b]
I'll be staying out of this unless it goes technical.
cf
100415-1956 EST
Make the phase angle 0, then the equation reduces to 1 + cos 2t. This wrong.
No I'm still here. I don't know where the thread will go. I don't have a preference.It isn't going anywhere. You made the assertion. You bugged out. Where do think its going to go? Perhaps you just prefer that it go away![]()
.... So trying to convince me of something differnet than what I observed yet do not adhere to is a waste of your time...
100417-0852 EST
Ham:
See
http://www.karlscalculus.org/trig_id.html
Go to equations 7.1b-10a and 10b
In post 155 I clearly indicated what sin^2 t was.
In post 179 you provided a plot of instantaneous power to a resistor without a specified relation to the voltage, and your assumption was for a cosine voltage curve without my knowing that. I had to assume you were referring to a sine wave because that was what I had defined in post 155, and the post to which you were questioning.
100417-0941 EST
Ham:
It is wrong for a sine wave and correct for a cosine wave.
Ham -Gar:
Thanks for link and I have no problem with trigometery equation and I am just to know from you
p = p + pcos2wt is right or wrong that is all.
Ham -
I'm not jumping in. I just have a question to help me follow along.
Can I rewrite p = p + pcos2wt as:
p(t) = VI + VIcos2wt or:
p(t) = VI (1 + cos2wt)
If I can, that will help me understand what your are saying. If not, then I am still lost - but that's okay, I'll catch up eventually.
cf
Trying to catch up here...gar, Smart, gunn, and others ,
please make clear for me.
p = P + Pcos2wt Is this wrong or Right
Ham -
cf
I followed your "proof" in post # 240.
p = P + Pcos2wt is correct when θv=θi, or pf=1.
Otherwise, the third term in your proof does not cancel out (i.e. where θv<>θi or pf<1).
p = P + Pcos2wt - Vm*Im*sin(0v - 0i)sin2wt/2
Unless you are computer language scripting, rewriting the equation with lower case p on both sides of the equation as cf did does not make any mathematical sense unless for all instances of t, cos2wt=0sorry for late answer you.Ham -
cf
yes, ofcourse you can incase you have pf = 1.
Ham -
cf
