- New Jersey
- Journeyman Electrician (retired)
Let's stay on topic.
My opinion is that a blanket policy of using all #12 in a dwelling unit is a waste. I'd much rather have well thought out circuitry using #12 and #14 as required then one wired with a "dummy" plan of using all #12 so mistakes don't get made. I've been in a large share of tract homes wired my marginally skilled laborers and they can figure out how to wire a home by code. Why can't the skilled electricians of the world do the same?![]()
so bottom line is this. Using #12 is not a better job its just a design choice unless required by specifications of a particular job. You can overload and/or underload a #12 and a #14 cirucuit.
If you were competitively bidding a job and you "chose" to use #12 on your own then your price would be higher and could cause you to lose the job.
.............ps...seen 4 houses burn to the ground in last couple of years because the contractor was all about cheap. cheap materials and WORST OF ALL...cheap labor. so when I hear guys talking cheap it strikes a nerve. I understand cost analysis and how to make a profit. If your AHJ allows #14, then use it, as long as its cheaper than 12/2![]()
There's a huge difference between being cheap and being economical/financially viable.
But keep in mind that you can't replace all the wiring & circuits normally done with 12 mono-a-mono for 14. You'll need more circuits, wire, labor, etc.
100% agree. strictly a design choice. but in my area we cant use it, even for smokes. we cant use #14 NM period, hence the cheaper price on #12 NM. One of those house fires started in a cieling fan box. Master Electrician installed new cieling fan with 12/3 nm, pancake box, no cable connector or bushing, cut the ground wire off, installed fan in a hurry. The rest is obvious. Family lost everything....![]()
No, ceiling fans. :roll:So is the AHJ going to outlaw #12 now?![]()
My point is cheap...er is not always better. My post on the house was off the original topic of OP. #14 makes sense to me with smokes and certain other applications, but I cant use it here. The inspector is a master electrician who cannot be influenced; so unfortunately I have to install per his will. Maybe he owns stock in the copper & wire industry.![]()
Wait...are you saying this "all #12 requirement" is simply something an inspector wants or is it actually a written building code requirement you can go look up at the city hall?
Not looking to mess wit ya - but I find wacky building codes interesting - you do have some wacky ones there....Its a city amendment to the NEC which has stood for many years AND many citys around here also adopted this amendment as well. The city is Lake Jackson Texas....look it up if you wish.
Ref(5) All references concerning the size of wiring are amended to require that all wiring be adequate for planned facilities, and in no case shall wiring be less than #12, including the switch legs and throughout the system.
support.:grin:This is a subject that could be debated on and on.
A big portion of it is personal preference.
We all know that #14 is rated for 15 amps And #12 rated for 20 amps.
In a lot of cases 15 amp general purpose would be fine,with a small cost savings.I personally stay with #12 thru-out the house.
You never know what joe homeowner will put on the circuits.
Also in a lot of the larger homes we do today the home-runs get pretty long.
Thats just my opinion.
Not looking to mess wit ya - but I find wacky building codes interesting - you do have some wacky ones there....Especially since it seems to be written in a Texan accent...
Not exactly out of the NEC style manual....
Ref
And by the way, its called a Texas draw...not an accent.
I have herd it referred to as a "Texas Drawl", but I guess not in Texas. :-?
