#12 only?
so bottom line is this. Using #12 is not a better job its just a design choice unless required by specifications of a particular job. You can overload and/or underload a #12 and a #14 cirucuit.
If you were competitively bidding a job and you "chose" to use #12 on your own then your price would be higher and could cause you to lose the job.
My opinion is that a blanket policy of using all #12 in a dwelling unit is a waste. I'd much rather have well thought out circuitry using #12 and #14 as required then one wired with a "dummy" plan of using all #12 so mistakes don't get made. I've been in a large share of tract homes wired my marginally skilled laborers and they can figure out how to wire a home by code. Why can't the skilled electricians of the world do the same? :confused:
That is good, and all work should be well planned, taking into consideration that code is a min standard, not even close to a wiring job that allows for future, but good enough to pass an inspection, and get paid, but the real question is are you building a tract house, or a custom home, the tract housing is usually min code, semi skilled labor, and little if any effort put into design, so when the new owner of a tract home wants that beautiful new fixture that draws 12A hung in the main entrance, to replace that 2 lamp 120W fixture, they have to rewire, or when they add recess lighting, they have to rewire or run new circuits, my thought is, most of the code min work, comes from designing for price. There will always be circuits that are 14 and efficent for the purpose.
You can reduce the price two ways: Fewer circuits means less home runs means less cabling.
And all that means less labor.
my apologies guys for my bad attitude...im truly regretful. however, I dont shop at the box stores because my business is a service business. I cannot afford to buy junk. We repair many newer installs because of faulty and/or poor workmanship. My customers depend on us ( ps we have over 1,000 clients BECAUSE of my strict policies of quality materials and workmanship) I dont do BULK construction plus BRAZORIA COUNTY DOES NOT ALLOW #14 FOR DWELLINGS...THEREFORE THE PRICE OF 12/2 AT MY REPUTABLE AND DEPENDABLE SUPPLIERS IS 64.75 FOR 250 FT AND 78.50 FOR 14/2. Is it fair? most of you would prob say no, but in my area this is how it is.
ps...seen 4 houses burn to the ground in last couple of years because the contractor was all about cheap. cheap materials and WORST OF ALL...cheap labor. so when I hear guys talking cheap it strikes a nerve. I understand cost analysis and how to make a profit. If your AHJ allows #14, then use it, as long as its cheaper than 12/2:)
.............ps...seen 4 houses burn to the ground in last couple of years because the contractor was all about cheap. cheap materials and WORST OF ALL...cheap labor. so when I hear guys talking cheap it strikes a nerve. I understand cost analysis and how to make a profit. If your AHJ allows #14, then use it, as long as its cheaper than 12/2:)
There's a huge difference between being cheap and being economical/financially viable.
But keep in mind that you can't replace all the wiring & circuits normally done with 12 mono-a-mono for 14. You'll need more circuits, wire, labor, etc.
100% agree. strictly a design choice. but in my area we cant use it, even for smokes. we cant use #14 NM period, hence the cheaper price on #12 NM. One of those house fires started in a cieling fan box. Master Electrician installed new cieling fan with 12/3 nm, pancake box, no cable connector or bushing, cut the ground wire off, installed fan in a hurry. The rest is obvious. Family lost everything....:mad:
So is the AHJ going to outlaw #12 now? :cool:
My point is cheap...er is not always better. My post on the house was off the original topic of OP. #14 makes sense to me with smokes and certain other applications, but I cant use it here. The inspector is a master electrician who cannot be influenced; so unfortunately I have to install per his will. Maybe he owns stock in the copper & wire industry.:)
Wait...are you saying this "all #12 requirement" is simply something an inspector wants or is it actually a written building code requirement you can go look up at the city hall?
Its a city amendment to the NEC which has stood for many years AND many citys around here also adopted this amendment as well. The city is Lake Jackson Texas....look it up if you wish.
Not looking to mess wit ya - but I find wacky building codes interesting - you do have some wacky ones there.... ;) Especially since it seems to be written in a Texan accent... :D Not exactly out of the NEC style manual....
(5) All references concerning the size of wiring are amended to require that all wiring be adequate for planned facilities, and in no case shall wiring be less than #12, including the switch legs and throughout the system.
Ref
This is a subject that could be debated on and on.
A big portion of it is personal preference.
We all know that #14 is rated for 15 amps And #12 rated for 20 amps.
In a lot of cases 15 amp general purpose would be fine,with a small cost savings.I personally stay with #12 thru-out the house.
You never know what joe homeowner will put on the circuits.
Also in a lot of the larger homes we do today the home-runs get pretty long.
Thats just my opinion.
support.:grin:
Ref
Sorry bud...Texas born and Texas bred...this inspector just so happens to be a friend of mine. And by the way, its called a Texas draw...not an accent. Its a brotherhood down here, so I'll suggest to any of you who may want to come to Texas to work, bring your "accent".
FINAL ANSWER: #14 MIGHT MAKE SENSE IN SOME AREAS, BUT HERE WITH SO MUCH AREA NOT COVERED BY AN AHJ...#12 IS SAFEST. IMHO.
QUINN IS OUT
