"I got an AFCI/GFCI breaker, and the inspector won't let me install it because it's not in the Code Book? What can I do?"
Close the panel and call the job done.
Roger
there are still people on the '02 and 05 codes
Remind him that the NEC is the minimum requirement. AFCI/GFCI exceeds requirements.
My point is, what do you do with technology that isn't addressed in the codebook, but is available on the market?
Like fuel cell systems, electrified truck parking spaces, electric vehicle charging systems and PV work?
All of those items are addressed.
Roger
They are NOW, but what do you do with a technology that ISN'T in the Code? There was a time that the Code doesn't address most of what's in your NEC now.
And most of us are not still using those older codes.
Where the older codes are still in place, 90.4 would give the AHJ direction as to a way to handle the situation.
If you have an inspector that won't allow you to use new technology then go with the flow or contest his/her position to a higher authority.
Roger
Is a local jurisdiction better equipped to decide all code changes than all the people listed in the front of your code book (CMP's)? Highly doubt it! I also think it is ridiculous that some locals are still on the '99 and '02 cycles and the '11 is out
Roger
You're preaching to the choir here, I still ask why inspectors have to rely on a listing instead of their own expertise.Why can't the industry that generates the technology adopt the proper installations. The NEC does not need to step in all over the place. The NEC does not need to place a rule on each and every type of installation all they need is a lot of general requirements. After all in my state the license board uses the term " normal standards of practice" .
If you recall we always need to refer to the manufactures spec and instructions a lot of the time when perfoming your work.
How can an inspector refuse your install when it's not prohibited?
Every five years would get my vote. CEU's and code updates for every three year cycle is too much. Not to mention the costs involved.
And that right there is a big reason why you will not see any changes in the three year cycle.Yea, but those who get that money for CEUs and updates and licenses will not want to change it.
