howardrichman
i've been installing either new or revamp existing weatherproof J-box outside septic tank riser for pump power/float set-up. I've removed many from inside tank riser; and install either lid just above grade, or mount pvc J-box to a post. I've either been installing cords w/strain relief conn. then sleeved for protection; or pvc sleeve directly into box- (no strain relief connn) into ground, and sealed w/putty.  For in-ground installation, I always just use strain relief conn. Personally, either way above ground; the cords will be protected, but i think only one way will pass inspection.
Please reply;
Howard Richman
			Please reply;
Howard Richman
