david
 - Pennsylvania
This bridge is manufactured to extend a rec. to a convenient location for do it yourselfers. You can try and call it an extension cord. That?s not what it?s doing. It is extending the building wiring from one location to another. There is no limit on the length of the NM cable no warning to use 12 gage wire if plugged into a 20 amp circuit. No way to inspect the NM cable buried in the wall. No requirement the supply rec. be in site of the load rec. The supply rec. could be in the basement and the load on another floor. No limit on any particular branch circuit you want to extend. I could use it in my bathroom to get my sink rec. to the floor so I can plug in my portable heater. Heck I don?t even have to stable my romex as I run it across my basement I can simply through it over my close line. After all it doesn?t have to be inspected and I sure do not to be qualified to install this extension cord. Yep I can see it now these bridges are going to show up everywhere any time someone needs a rec. where there is not one currently after all anyone can install an extension cord.
