I give no thought to whether you will or will not respond. Your participation is your own business and I am OK with whether you do or do not participate. I participate because I want to and I assume you do the same. There is no "you and me".Mivey has been very careful to not say something that will draw me out of the woodwork, but surely he must know that this would.
The phase angles are mathematical, not real. So with this quotation, the same question I posed to Rattus is now posed to Mivey.
Since you are here first, then here is the original question:
If the phase angles were real and not mathematical, then your scope images should show a noise anomaly that exists on the positive peak of the primary winding on both secondary waveforms at their positive peaks too. If this were simply an inversion (which it is), then that noise anomaly would appear on both positive and negative peaks simultaneously.
Since this question has apparently gone unnoticed from you guys for over a week, I think it best to make sure it does not slip past your purview again. So I will make it more obvious:
Rattus, Mivey, Besoeker
Answer my Question!
If you claim this is a real phase shift and not mathematical, then explain why your scope does not show a noise artifact at the same 180 degree shift?
What I do care about is that you just confirmed that the phase shift is mathematical, not real.
It can supply either one. And you can use either.Surely you are talking about RMS voltage in a 120V single phase supply.In that case it has only one voltage.But think of the 120 v A.c supply as generator of voltage wave.In this case it can generate two voltage waves with 180 degree displacement by reversing the measuring leads.
The equation is perfectly valid. But in one of the earlier posts, someone ignored the signs in order to claim that V1 and V2 are actually in phase. I am asking anyone who knows math better than I to explain it to me.I'm kind of confused why you are asking this. It is actually the founding basis for your argument. This is the mathematical principle that permits you to take a physical inversion and turn it into a mathematical phase shift. If you reject this mathematical equality, then you can't even claim that you have an "apparent" phase shift, let alone a "real" one.
I believe someone else said with a trig identity. What identity?sin(wt + 180) = -sin(wt)
Can anyone explain it to me?
Answer my Question!
In other words, we have both in-phase voltages and phase-opposed voltages at the transformer.
Absurb if that was actually my argument. Look at the graphic I posted in #847. Both voltages are there and the graphic is not animated to change the connections back and forth. The connections are static.What an absolutely positively absurd argument; Yeah but if they were connected differently we would get different results.
As I pointed out before, windings in themselves do not have a phase. It is the voltage in the winding that has a phase. To say a winding has a phase you are associating it with a voltage and to do that you must pick a positive direction or you can't compare phases.There are two windings on a common core.
As agreed to be Besoeker, these are real physically defined in-phase windings.
I have repeatedly used the industry standard terminal designations X1-X2&X3-X4. This is the real world.
Please show me where I said any of the millions were connected that way. I said the transformer on the right of my graphic is connected the same as the standard residential transformer.You then say to change the reference, but I am talking about physical connections, so the only way to change the reference is to rewire the source
You talked about millions of single phase transformer connections, how many of them are connected in your arrangement of X2-X1&X3-X4?
As are the connections on the right side of my graphic.Maybe Besoeker could post the waveforms from your suggested connection, so they can be performed. Of course he won't be able to do this with a center-tapped transformer as its connections are fixed by the manufacturer.
Based on your responses, my argument would be that you haven't really looked at my graphic and that you are just making assumptions about what is there based on what you want to argue against.I can guess your rebuttal will still be; but the math can be made to work, just open your eyes to other possibilities.
and just like I included in my graphic.Over and over, I have not been talking about 'what if', I have been discussing the actual transformer connections found in millions of installations in the real world - just like the OP asked about.
Being the "someone else" had he said he accepted trig identities; I would have followed up with "Why would you need to? The term "wt" is identically equal to “wt” on both sides of the equation except to folks with a runaway oscilloscope.” Instead he demanded an answer limited to high-school algebra.120218-0933 EST
In post #981 rattus simply ask how you could remove the - sign from the equation with no other change to the equation.
If I use the identity
sin (a +/- b) = sin a * cos b +/- cos a * sin b and substitute b = 180, then
sin (a +/- 180) = sin a * (-1) +/- cos a * (0) = - sin a
This identity does not remove the - sign. Therefore, I conclude there is no identity that removes the - sign for the 180 deg shift because it would be a contradiction.
Being the "someone else" had he said he accepted trig identities; I would have followed up with "Why would you need to? The term "wt" is identically equal to ?wt? on both sides of the equation except to folks with a runaway oscilloscope.? Instead he demanded a ?algebraic? answer beyond typical high-school math.
But'"a" is identically equal to ?a? on both sides of the equation' applies to your math too.
I want to submit that I have given you numerous examples that I believe more than adequately demonstrate my understanding of the differences between AC and DC.I want to submit that I gave you multiple chances to prove your understanding of differences between AC and DC voltages.You simply dodged.I humbly submit you better try once more.
	I say it like this:How do you say there are two phases?
No Mivey, you have never answered the question. You've dodged it. I never said anything about a "time shift". The three of you keep saying that the phase shift is "real" not "mathematical".Myself and others have answered your question but you just did not like the answer I guess. This issue has been discussed many times in previous threads. You make the assumption that when we speak of a phase difference that it means there must be a time shift. The terms "a phase shift" and "a difference in phase" are used interchangeably.
Where did I claim that it was a physical phase shift?If it is a physical phase shift, as the three of you keep claiming,
So what you are saying when you jump back to saying it is "ideal" is that it is mathematical only and not real. I don't have a problem with you saying there is a mathematical phase shift. I take issue with you saying it is real. If it is a real phase shift, then there is no minus sign that would be necessary to move the noise to the negative half cycle. Your phase shift eliminates the minus sign. So if the noise is appearing in the negative half cycle as you now agree, then the only way to get it there is with an inversion that mathematically appears to be a phase shift. You can't have both.You are correct about the noise, but no one cares because we are discussing ideal waveforms. No noise is allowed.
I didn't say it was ideal.So what you are saying when you jump back to saying it is "ideal"
I didn't say it was a mathematical phase shift.I don't have a problem with you saying there is a mathematical phase shift.
Then explain how the circuit in post #1004 works.I take issue with you saying it is real.
Right Here!Where did I claim that it was a physical phase shift?
If they weren't real I couldn't get this:.....The phase angles are mathematical, not real.
Where in that post does it say that they are physical?Right Here!
I know you didn't say it was mathematical. That's why I'm taking issue with it. You're claiming its real.I didn't say it was ideal.
It works by inversion that is mathematically represented as a phase shift. But you're dodging the question.Then explain how the circuit in post #1004 works.
When you say it is "real," that's physical. When you deny that it is a mathematical equality, that makes it physical. It's not a real phase shift. It is mathematical.Where in that post does it say that they are physical?
