goldstar
- New Jersey
- Electrical Contractor
Is it acceptable to use back-lit (neon) switches to switch receptacles in a bedroom ? What ends up happening when you plug in a receptacle tester is one light lights solid and the other flickers as a result of feeding thru the neon bulb. Obviously the back-light feature in the switch won't be visible unless you have a lamp with a std. A-bulb installed. Just wondering what an EI would say.
