But is it worth the time/hassle?Small claims court. In NJ, you can go up to $5,000 IIRC.
We don't know how much is owed.
Just a passing thought or two. How much would it cost to torque the connections, placate the recalcitrant customer, and get paid? ... In short, is it worth the aggravation?
Quite so.I have no idea where the customer is getting his ideas from, the internet is a terrible thing for the ignorant.
-Hal
Yes, it is very dependent on the money in play. If it's $100, you might say "just keep it." If it's $1,000 then you might want to start with the letter, previously suggested, that all devices were installed per the manufacturer's instructions so please pony up the retainage. If they then insist that the EC come back and repeat that work, it's time to point out that they can't unilaterally modify the contract scope of work after completion and successful inspection. Then it's small claims court. Unless the amount is over $15,000 (I double checked NJ) don't involve a lawyer unless it's just a demand letter. Filing in small claims for NJ is $15.00.But is it worth the time/hassle?
That spec looks to be copied and pasted off of someplace where this was discussed and somebody posted it. No way would a home owner come up with that nor would they think there is an issue with compliance unless they read some of the threads here or other places where we talk about the issue among ourselves.
-Hal
They probably seen it on a YouTube how to video! LOL!Quite so.
This, from the homeowner, interested me:
"Electrical Contractor shall torque all electrical connections, including lugs, circuit breakers, switches, and receptacles to manufacturers specifications using a calibrated torque screwdriver or calibrated torque wrench. Electrical Contractor will sign a letter that he has torqued the above connections and submit the letter to the homeowner. "
Not what you would expect from the average homeowner. And, if the installation has already passed inspection..........how could he know it wasn't already done in accordance with the rules...........
I feel sorry for the EC being put in this position.
That was my point.If they then insist that the EC come back and repeat that work, it's time to point out that they can't unilaterally modify the contract scope of work after completion and successful inspection.
Again . . .It's the fact that he waited until the job is finished and thinks he can demand a letter from the electrician by withholding payment.
Unless it's in the contract I don't see any reason to give the homeowner a letter stating anything.
Yeah, a fast one.I agree. the customer is pulling something.
-Hal
Removing, re-torquing and replacing every device plus the service panel and meter lugs in the typical house here could run into the thousands for which they have no intention of paying. For this you have no recourse in collecting it because it's an extra with no signed change order.
Just reply with a letter that everything has been installed per manufacturers instructions, if torquing was required it was done. Also state that the inspector requires connections to be torqued when required, has inspected all work and has signed off on it.
If that doesn't work, it's obvious that the customer is trying to screw you out of your final payment. A letter from your attorney is in order. Mention putting a lien on the property.
I have no idea where the customer is getting his ideas from, the internet is a terrible thing for the ignorant. Quite possibly they found it here. Maybe we should consider closing this forum to the public. Allow access only to members who sign up and are qualified. We don't need DIYs and homeowners looking here because they have no idea what they are reading.
-Hal
As Hal mentions, even during any deliberations be sure to start lien procedures before any time limitations, this might simply be writing a letter.After final sign off by inspector, I received this demand from the homeowner:
Prior to final payment,
What would you do?
Quite. But the "do nothing" option won't get the bill paid.Unless it's in the contract I don't see any reason to give the homeowner a letter stating anything
Problem is if you close it to the public many potential legitimate users maybe will never check it out and never join.
I agree.Problem is if you close it to the public many potential legitimate users maybe will never check it out and never join.
