electrofelon
- Cherry Valley NY, Seattle, WA
Ok good to know I didn't make that up. I hate when I find out that something I was so sure was true, my brain fabricated
I haven't checked in here for a looong time. I see nothing has changed.![]()
I resemble that remark!I haven't checked in here for a looong time. I see nothing has changed.![]()
Agreed, but it's definitely SOP in the industry, lol.Your way is not the only way, and calling people "not electricians" because you don't do it that way or like that way, is not right.
How are you? Good to see you.I haven't checked in here for a looong time. I see nothing has changed.![]()
My dad was a plumber, pipefitter, and welder. He worked on boilers a lot, but he also did Residential Plumbing from the late 50s to the late 70sAgreed, but it's definitely SOP in the industry, lol.
I'm not being as harsh about it as you likely think I am being. I'm a fairly laid back individual.
I still stand by the comment because of the lack of trade specific skill involved in splicing wires without the aforementioned applied knowledge.
I would have "become an electrician" much sooner if I didn't have to first master this ability.
Every sparky I've ever worked for or with have always mocked the idea of "no pre-twist" as just being shotty work that's more concerned about micromanaging milliseconds than it is quality.
I like plastic boxes, but not fiberglass ones; they shatter too easily. I wonder what I would qualify as?Maybe you also feel that people who use plastic or fiberglass wall boxes are faketricians, too![]()
A stooge?I like plastic boxes, but not fiberglass ones; they shatter too easily. I wonder what I would qualify as?![]()
I love the fiberglass boxes because they hold their shape when the nails are driven tight, and because the clamps are easy to work with. The wires come out toward the front instead of going down to the back of the box.I like plastic boxes, but not fiberglass ones; they shatter too easily. I wonder what I would qualify as?![]()
Oh, a wise guy! Nyuk, nyuk, nyuk!A stooge?
Oh, another wise guy! Nyuk, nyuk, nyuk!I told him "you're not supposed to hit the box, you're only supposed to hit the nail."![]()
I think the premium Carlon are tapped.Im with ya. Another thing I love about the fiberglass and HATE about plastic is the tapped device holes in the fiberglass. Maybe there are some plastics that are tapped but the junk carlon boxes are not.
3M's B/G+ wire nuts are rated for up to six #10 conductors, solid and/or stranded.I went through the ideal wirenut catalog and can't find anything listed for more than 5 wires.
Exactly. It's very common to use the rhetoric I'm using here, especially when you learn or become accustomed to one particular method.My dad was a plumber, pipefitter, and welder. He worked on boilers a lot, but he also did Residential Plumbing from the late 50s to the late 70s
He expressed similar sentiments about the guys who insisted on using junk copper water lines instead of threading together galvanized pipe
And he expressed similar sentiments about guys who started using ABS drain lines instead of pouring oakum joints
Really, though, I ain't mad at you. I see some guys all the time doing stuff that I think disqualifies them
I worked at 2 large companies that had a lot if vibration in some areas where you had to twist the.pressure connectors ( no such thing as wire nuts in NEC ) then apply tape over it. Wish I had a dollar for every time I went behind a lazy sparky who only throw a pressure connector on 4 or 5 #12 wires and they came loose and sparked after remiving connector. Best pratice is to Always strip all # 14 to 10 guage wires 7/8" , pre twist with linesmen pliers so that you get 3 full turns, trim off ends even then apply tape. Tip be a friend & leave a turned over flap at end of tape.I never have, But a fellow employee tells me I should especially with 277 V. your thoughts? thank you for your help.
That's not how I read it.3M's B/G+ wire nuts are rated for up to six #10 conductors, solid and/or stranded.
https://multimedia.3m.com/mws/media/37675O/3m-b-g-performance-wire-connector.pdf
I had a "skilled trades" temp service send out a skilled residential electrician once, and I wanted him to wire a detached garage while I worked in the house.Exactly. It's very common to use the rhetoric I'm using here, especially when you learn or become accustomed to one particular method.
I actually agree with @Little Bill that it's "not right," which is why I clarified that I'm not being as harsh about it as he may think I'm being.. although I completely understand why one would/could take it that way.
It's a strange, tricky balancing act between (1) newer, more efficiently technology and (2) what skills qualifies one to be an "electrician."
If we continually come out with tech that eliminates the need for base skills (such as splicing with a lineman's pliers), anyone can be an electrician. That's my issue with the whole idea of not pre-twisting. Just spinning a cap on eliminates as a very basic, but very necessary skill.
The manufacturer's don't care about this, which is why we need to be careful. They just wanna sell product.
