gar
- Ann Arbor, Michigan
- EE
221203-1040 EDT
Therealcrt:
I want to start by ignoring your dimmer need, and how and when they should work.
Next is a safety question and whether you should ever be able to turn everything off. That subject needs some input on philosophy. So also ignore that to start.
Now that gets us down to the logic that you want.
With the GE RR relay type system you have switches, the RR relay, with a SPST power switch that is physically bistable. This means the mechanical switch has two stable states that hold the last set condition independent of available power. The same function as an ordinary toggle switch. The relay also has two coils, a set and a reset, the relay only requires a short pulse of energy to a coil to change its state. Two or more pulses of energy to the same coil has no effect on the output state beyond the first pulse.
This means that to control the state of the relay that only s momentary closure of an input switch is required to change the relay state. Thus, many SPST-NO momentary switches can be in parallel to control a single relay coil.
The logical connection of various momentary SPST-NO switches then determine how your system works.
Therealcrt:
